Pool Missing
daftfool
Originated as a missing pool on startup, read a few posts about similar but cannot find anything that directly relates.
zpool list
[root@freenas ~]# zpool list
NAME           SIZE  ALLOC   FREE  CKPOINT  EXPANDSZ   FRAG    CAP  DEDUP  HEALTH  ALTROOT
FREENAS       8.12T  2.74T  5.38T        -         -     0%    33%  1.00x  ONLINE  -
freenas-boot  7.50G  1.51G  5.99G        -         -      -    20%  1.00x  ONLINE  -
[root@freenas ~]# ^C
[root@freenas ~]#
zpool status -xv
[root@freenas ~]# zpool status -xv
  pool: FREENAS
 state: ONLINE
        corruption.  Applications may be affected.
action: Restore the file in question if possible.  Otherwise restore the
        entire pool from backup.
   see: http://illumos.org/msg/ZFS-8000-8A
  scan: scrub repaired 0 in 0 days 03:42:50 with 9 errors on Wed Nov 27 06:02:07 2019
        NAME                                          STATE     READ WRITE CKSUM
        FREENAS                                       ONLINE       0     0     0
          gptid/514cd7dd-d91c-11e8-9d18-000c290b2ac7  ONLINE       0     0     0
        FREENAS/.system/rrd-2272cbf872134cd4ab2b960f79d0a321:/localhost/df-mnt-FREENAS/df_complex-reserved.rrd
        FREENAS/.system/rrd-2272cbf872134cd4ab2b960f79d0a321:/localhost/zfs_arc_v2/gauge_arcstats_raw_counts-mutex_miss.rrd
        FREENAS/.system/rrd-2272cbf872134cd4ab2b960f79d0a321:/localhost/zfs_arc_v2/gauge_arcstats_raw_size-size.rrd
        FREENAS/.system/rrd-2272cbf872134cd4ab2b960f79d0a321:/localhost/zfs_arc/io_octets-L2.rrd
        FREENAS/.system/rrd-2272cbf872134cd4ab2b960f79d0a321:/localhost/zfs_arc_v2/gauge_arcstats_raw_l2writes-l2_writes_error.rrd
        FREENAS/.system/rrd-2272cbf872134cd4ab2b960f79d0a321:/localhost/zfs_arc_v2/gauge_arcstats_raw_l2write-l2_write_buffer_bytes_
scanned.rrd
        FREENAS/.system/rrd-2272cbf872134cd4ab2b960f79d0a321:/localhost/cpu-0/cpu-user.rrd
        FREENAS/.system/rrd-2272cbf872134cd4ab2b960f79d0a321:/localhost/cpu-0/cpu-nice.rrd
        FREENAS/.system/rrd-2272cbf872134cd4ab2b960f79d0a321:/localhost/aggregation-cpu-max/cpu-interrupt.rrd
[root@freenas ~]#
glabel status
[root@freenas ~]# glabel status
                                      Name  Status  Components
gptid/2b680521-d921-11e8-bb7a-000c290b2ac7     N/A  da0p1
gptid/514cd7dd-d91c-11e8-9d18-000c290b2ac7     N/A  da1p2
[root@freenas ~]#
smartctl -a /dev/da1 (Guess this highlights a different issue!)
[root@freenas ~]# smartctl -a /dev/da1
smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.2-STABLE amd64] (local build)
Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
Vendor:               Adaptec
Product:              Array
Revision:             V1.0
User Capacity:        8,987,208,581,120 bytes [8.98 TB]
Logical block size:   512 bytes
Serial number:        598CE7B200
Device type:          disk
Local Time is:        Wed Nov 27 09:18:28 2019 PST
SMART support is:     Unavailable - device lacks SMART capability.
Current Drive Temperature:     0 C
Drive Trip Temperature:        0 C
Read defect list: asked for grown list but didn't get it
Error Counter logging not supported
Device does not support Self Test logging
[root@freenas ~]#
Amateur but I don't think I have a backup of the pool information, anything relating to creating a new pool wipes the disks which I would obviously like to avoid.
Can anyone offer some advice on anything else to check next?
Virtual FreeNas 11.2-RC2 running on ESXI server
Adaptec raid controller for 4 x 3tb disks (showing as 8tb drive)
(not sure what other information is useful or relevant).
So you are missing your main pool? Run zpool import from a FN host terminal see if that grabs it.
As far as the corrupt files, id grab a config backup from the GUI, then you might think about a reinstall to fix the errors current version is 11.2-U7, you are running a pretty old RC version.
Chris Moore
You shouldn't do that with FreeNAS whether it is bare metal or virtual. FreeNAS needs direct access to the physical disks.
Matt_G
What Chris said.
Looks to me like the Adaptec has the four drives in a RAID array and then presented that single virtual drive to FreeNAS.
FreeNAS thinks it has a pool consisting of just one drive; therefore, you lose almost all the benefits of ZFS.
daftfool
What Chris said.
Yes, I will look to change it after, but for not I just wish to attempt to restore what I had.
zpool import FREENAS advises
'cannot import 'FREENAS': a pool with that name is already created/imported, and no additional pools with that name were found.
However, via the GUI I still have no pools.
Chris Moore
Based on the content of your post, the pool is there it may simply be the network share that's not working right
daftfool
Thanks again I will investigate this. However first check doesn't look promising as there doesn't appear to be any network sharing set up :S
Looks like the pool and network share configuration has been wiped, but I don't know how to restore that without wiping the disks. I will continue looking.
daftfool
Update *All Fixed*
Re-read insturctions from previously and reapplied after a night sleep thinking about it.
Exported from CLI, imported via WEB GUI, which made the volume available to import.
Imported the volume, and then set up a new network share.
Now to backup the backup and get rid of the hardware raid.
Thanks for the help.
