Ive run into a strange issue with a zpool running FreeNAS-8.2.0-BETA2-x64 (r10638) which I'm hoping someone can help me with.
It all appeared to start several hours after I made an amendment to /boot/loader.conf after I had a panic (Kernel Panic: Kmem_malloc kmem_map too small). To which I added vm.kmem_size = 1.5x mem and vfs.zfs.arc_max = .5x mem and reloaded. Ive rolled back these changes but I still have an issue with one of my pools. What I now have is when I go to access this particular mounted pool either via a share or straight from the terminal the second level of directories are inaccessible (even a listing freezes). There doesn't appear to be anything of value in syslog either. I've attempted to run a scrub and all this does is freeze the particular session im in and it renders all future status checks against the pool inoperable (ie I can run a status but after attempting a scrub a status freezes the cli). When I attempt to shutdown I also get an error relating to processes that wont die (or something to that effect). My other pool is working fine and its not having any issues.
Im thinking from a bit of reading around perhaps an export/import, but Im interested in seeing if anyone had run into something similar and have a more informed idea.
This is what I see in relation to the pool;
[root@hi] ~# zpool status -x
all pools are healthy
[root@hi] ~# zpool status -v Store
pool: Store
state: ONLINE
scrub: none requested
NAME STATE READ WRITE CKSUM
Store ONLINE 0 0 0
raidz1 ONLINE 0 0 0
ada6p2 ONLINE 0 0 0
ada4p2 ONLINE 0 0 0
ada8p2 ONLINE 0 0 0
raidz1 ONLINE 0 0 0
ada5p2 ONLINE 0 0 0
ada1p2 ONLINE 0 0 0
ada2p2 ONLINE 0 0 0
ada3p2 ONLINE 0 0 0
errors: No known data errors
pool: Store
state: ONLINE
Store ONLINE 0 0 0
raidz1 ONLINE 0 0 0
ada6p2 ONLINE 0 0 0
ada4p2 ONLINE 0 0 0
ada8p2 ONLINE 0 0 0
raidz1 ONLINE 0 0 0
ada5p2 ONLINE 0 0 0
ada1p2 ONLINE 0 0 0
ada2p2 ONLINE 0 0 0
ada3p2 ONLINE 0 0 0
