Pool does not show in GUI
Hi there. I recently installed truenas scale and now I'm trying to create my pool
zpool create vdata raidz2 /dev/sda /dev/sdb /dev/sdc /dev/sdd -o ashift=12
I ran the command above but my pools do not show up in the Storage section but I can see the data set in the dataset section
Here is the output of the zpool status command:
That's because you should have created the pool from the GUI. Export the pool, Import it in the GUI.
