joe776
- Apr 19, 2015
I tried to remove encryption from a pool by using this guide: https://forums.freenas.org/index.ph...om-a-zfs-volume-while-keeping-the-data.16467/
(Basically taking the device offline, detach from GELI, replace, resilver, repeat)
I did this for the first drive and everything looked fine. All devices and the pool were online after the resilvering. However, after a reboot the resilvered disk without encryption is marked as unavailable and the pool is degraded.
Does anybody have an idea how to get the disk online again?
Things tried so far:
I'm thankful for any help or pointers on how to get the device online.
Cheers
freenas# zpool status
datengrab DEGRADED
raidz2-0 DEGRADED
8636046042145075812 UNAVAIL was /dev/gptid/d7f1c09c-da08-11e3-87a0-38eaa7a49a3c
gptid/d8c98d9d-da08-11e3-87a0-38eaa7a49a3c.eli ONLINE
gptid/d9991265-da08-11e3-87a0-38eaa7a49a3c.eli ONLINE
gptid/da733091-da08-11e3-87a0-38eaa7a49a3c.eli ONLINE
gptid/db4bf754-da08-11e3-87a0-38eaa7a49a3c.eli ONLINE
gptid/ee3135f2-da08-11e3-87a0-38eaa7a49a3c.eli ONLINE
- freenas# zpool replace datengrab 8636046042145075812 gptid/d7f1c09c-da08-11e3-87a0-38eaa7a49a3c
invalid vdev specification
/dev/gptid/d7f1c09c-da08-11e3-87a0-38eaa7a49a3c is part of active pool 'datengrab'
So this did not work...
- freenas# zpool export datengrab
freenas# zpool import datengrab
This did not change anything
Cheers
