Hi all,
So i got Plex Plugin installed and using the Media user & group to set this up.
Was following this command to be exact - https://www.ixsystems.com/community...-write-permissions-to-your-data.27273/page-20
1. Installed plug-in and stopped
2. Add mount points to jail
3. entered shell through jail
4. followed step 2 but instead of /var/db/PLUGIN which i can't seem to find is used /var/run/transmission (idk but it worked)
So I did this for my media user & group successfully
then chwon -R media:media /var/db/plex/
then when i go to start the process again it displays this as of below, the process is defiantly not running already, i tried another forums post which was suggesting to create a new directory and then change the ownership to run the process. I tried logging into putty with my media user but didn't work.
- In the jail, add a user with a matching UID as the owner of the data dataset/folders.
- Code:
pw useradd -n USER -u UID -d /nonexistent -s /usr/sbin/nologin
 - Code:
 - In the jail, change the user the plugin runs as, and change ownership of the data-directory.
- Code:
service PLUGIN onestop
chown -R USER:GROUP /var/db/PLUGIN
sysrc 'PLUGIN_user=USER'
service PLUGIN start
 - Code:
