Plugins won't start after upgrading
BlazeStar
I just upgraded to TrueNAS (TrueNAS-12.0-U1.1).
4 out 5 of my plugins don't work.
I tried upgrading through the CLI with
iocage upgrade XXX
Everything has been upgraded:
| JID |     NAME     | STATE |   RELEASE    | IP4  |
| 10  | jackett      | up    | 12.1-RELEASE | DHCP |
| 11  | plex         | up    | 12.1-RELEASE | DHCP |
| 12  | radarr       | up    | 12.1-RELEASE | DHCP |
| 13  | sonarr       | up    | 12.1-RELEASE | DHCP |
| 14  | transmission | up    | 12.1-RELEASE | DHCP |
None of the plugins are accessible except for Jackett.
I read something about devfs_ruleset.
I checked it ou and all jails are set to 4, which is what I understand should be the correct value.
I tried rebooting the system, updating from the GUI, restarting every plugin... nothing works.
Please HALP!!!
Did you run pkg upgrade in those jails after the upgrade of the jail?
BlazeStar
I'm not sure what you mean?
I ran iocage upgrade NAME and it appeared to upgrade everything?
Are there additional commands I should be running?
That command you ran upgrades the jail Operating System.
What I'm suggesting is you still need to upgrade all of the software to match it:
iocage pkg plex upgrade
For example.
BlazeStar
For example.
Thanks for your reply!
Ok I just ran all the pkg upgrade for all iocages.
I rebooted the system just to make sure.
Still, all my plugins and not accessible except Jackett.
I'm too much of a n00b to understand what's going on.
Is there anything I can do to get some more info on the problem?
Did you see the upgrade of packages happen? (you may have needed to enter Y without necessarily seeing a prompt for it).
Alternatively do:
iocage console plex
then
pkg update && pkg upgrade
to make sure it goes through.
You may need to look into starting the service from inside the jail to see a detailed error.
BlazeStar
Alternatively do:
iocage console plex
then
I completed that, for each iocage, and everything went through without errors.
(and yes it prompted me every time for confirmation and I pressed Y)
Still can't access my plugins though :confused:
BlazeStar
Anyone could help out?
None of my plugins work anymore except for Jackett :(
Where can I look to figure out what's wrong?
Baenwort
Did you check to see if the plug-ins changed from getting their own IP to being NATed from the NAS IP? I had this problem as most of the plug-ins have been updated by iX (don't know why) to be using ports off the NAS IP and this causes problems with some plug in combos.
BlazeStar
All the jails get their IP from DHCP.
In the jails option : DHCP, VNET and Berkely Packet Filter are enabled.
NAT is disabled.
Is that correct?
above&beyond
I also just upgraded to TrueNAS-12.0-U2. I can't access Sonarr or Radarr through the webui even though both plugins and jail show they are running. I receive an ERR_CONNECTION_REFUSED error message in Google Chrome. Deleting the plugins and installing from scratch yields the same result.
DHCP, VNET and Berkely Packet Filter are enabled. NAT is disabled.
BlazeStar
Does anyone have any idea where I could start to investigate?
Initially, I just installed the plugins from the GUI...
Any log I could look into? Or anything else?
It'd really like to get those plugins back online.
Or if I need to start from scratch I'd like to know ASAP !
Samuel Tai
What version of FreeNAS did you upgrade from?
Samuel Tai
No, that's what you upgraded to. What version did you start from?
BlazeStar
Well, I'm about to start the very painful process of installing all the plugins from scratch and trying to figure ou how to import the database from the non functioning plugins.
Before I do that, is there a charitable spirit who would have a suggestion to try to fix my plugins?
Thanks!
ThreeDee
maybe it's a permission issue of some kind .. I'm a noob's noob so I'm just taking a stab here .. I've been struggling getting UniFi6 installed but finally got it sorted out .. but anyhoo .. maybe try
iocage exec radarr chmod u+x /usr/local/etc/rc.d/radarr
iocage exec radarr sysrc "radarr_enable=YES"
iocage exec radarr service radarr start
Run from main shell and change "radarr" to whatever the actual name of your jail is
and if that actually works ..do the same for your other jails
