RegularJoe
- Aug 19, 2013
Hi All,
In the GUI and from the command line I am trying to get Zoneminder to use devfs_ruleset 4 and it keeps defaulting to 1000.
Is there a way to fix this?
Thanks,
Joe
Thanks,
Joe
root@freenas[~]# iocage list +------+-----------------+-------+--------------+------------+ | JID | NAME | STATE | RELEASE | IP4 | +======+=================+=======+==============+============+ | None | bacula-server | down | 11.2-RELEASE | DHCP | +------+-----------------+-------+--------------+------------+ | None | speedtestserver | down | 11.3-RELEASE | 172.16.0.2 | +------+-----------------+-------+--------------+------------+ | 4 | zm | up | 12.1-RELEASE | DHCP | +------+-----------------+-------+--------------+------------+ root@freenas[~]# iocage stop zm * Stopping zm + Executing prestop OK + Stopping services OK + Tearing down VNET OK + Removing devfs_ruleset: 1000 OK + Removing jail process OK + Executing poststop OK root@freenas[~]# iocage set devfs_ruleset=4 zm devfs_ruleset: 4 -> 4 root@freenas[~]# iocage start zm No default gateway found for ipv6. * Starting zm + Started OK + Using devfs_ruleset: 1000 (iocage generated default) + Configuring VNET OK + Using IP options: vnet + Starting services OK + Executing poststart OK + DHCP Address: 10.1.1.209/24 root@freenas[~]#
