Trying to bring current the plex jail on TrueNAS 12.0 U1.1..
WB3FFV
I have a quick query hopefully someone can shine a light on. As I have seen from many articles around here, I have loaded plexmediaserver-plexpass package on my NAS, and it's been running great. Where I am stumped is every other jail I have says it's release 12.2, but this jail says it's 12.1.
| JID |       NAME        | STATE |   RELEASE    |
| 4   | tnas720-adguard   | up    | 12.2-RELEASE |
| 5   | tnas720-lms       | up    | 12.2-RELEASE |
| 2   | tnas720-nextcloud | up    | 12.2-RELEASE |
| 9   | tnas720-plex      | up    | 12.1-RELEASE |
So I thought from the various posts, I just needed to do an upgrade of the jail, so logged in to take a peek. I noticed when I logged into the shell, it's reporting:
FreeBSD 12.2-RELEASE-p2 663e6b09467(HEAD) TRUENAS
I thought OK, that is strange, it says it's current, but the plugin page, and jails page says it's behind. So I thought what the heck, let's run the upgrade routine, and maybe it will update, but on running 'iocage upgrade -r 12.2-RELEASE-p2 tnas720-plex' I get listings of packages and such it would update, but then:
Branch 12.2-RELEASE does not exist at https://github.com/freenas/iocage-plugin-plexmediaserver-plexpass.git!
Using "master" branch for plugin, this may not work with your RELEASE
Installing new pkgs...
Repo: iocage-plugins already exists, skipping!
Testing Host DNS response to pkg.FreeBSD.org
Testing tnas720-plex's SRV response to pkg.FreeBSD.org
Testing tnas720-plex's DNSSEC response to pkg.FreeBSD.org
Installing plugin packages:
- plexmediaserver-plexpass...
- ffmpeg...
Cloning git repository
tnas720-plex successfully upgraded!
Still even after all of this, and restarting the plex server, it still says it's release 12.1. Probably not a huge deal, as everything is running, but I am still left scratching my head as to why this one jail will not show it's updated to 12.2 so current with everything else in the system.
Any insight would be great...
PPete27
To upgrade the Iocage Jail release (I haven't tested this with my Plex Jail yet, so do at your own risk :)) run "sudo icoage upgrade -r 12.2-RELEASE <jail name>" from the main Truenas shell
hervon
Small typo: "sudo iocage upgrade -r 12.2-RELEASE <jail name>"
WB3FFV
This was done, hence the error about Branch 12.2 listed above, about there not being a 12.2, so it had to use master. In fact here is my exact command input as root on the main server:
# iocage upgrade -r 12.2-RELEASE-p2 tnas720-plex
tnas720-plex is the name of my jail, as you can also see from my iocage list in my original posting. It's long, but I will attach the full output as code below from the run, and I see lua failures, no clue what that means, but it says successful in the end.
Here is the output from the iocage upgrade run:
Snapshotting tnas720-plex...
Updating plugin INDEX...
Running upgrade...
Checking integrity... done (0 conflicting)
Deinstallation has been requested for the following 63 packages (of 0 packages in the universe):
Installed packages to be REMOVED:
        aom: 2.0.1_1
        argp-standalone: 1.3_4
        bash: 5.1.4_1
        bash-completion: 2.11,2
        ca_root_nss: 3.58
        dav1d: 0.8.1
        expat: 2.2.10
        ffmpeg: 4.3.1_9,1
        fontconfig: 2.13.92_2,1
        freetype2: 2.10.4
        fribidi: 1.0.10
        gettext-runtime: 0.21
        glib: 2.66.4_1,1
        gmp: 6.2.1
        gnutls: 3.6.15
        graphite2: 1.3.14
        harfbuzz: 2.7.4
        indexinfo: 0.3.1
        jpeg-turbo: 2.0.6
        lame: 3.100_2
        libX11: 1.6.12,1
        libXau: 1.0.9
        libXdmcp: 1.1.3
        libXext: 1.3.4,1
        libXfixes: 5.0.3_2
        libass: 0.15.0
        libdrm: 2.4.104,1
        libepoll-shim: 0.0.20201229
        libffi: 3.3_1
        libiconv: 1.16
        libidn2: 2.3.0_1
        libogg: 1.3.4,4
        libpciaccess: 0.16
        libpthread-stubs: 0.4
        libtasn1: 4.16.0_1
        libtheora: 1.1.1_7
        libudev-devd: 0.4.2_1
        libunistring: 0.9.10_1
        libv4l: 1.20.0
        libva: 2.10.0
        libvdpau: 1.4
        libvorbis: 1.3.7_2,3
        libvpx: 1.9.0
        libx264: 0.161.3020
        libxcb: 1.14_1
        libxml2: 2.9.10_2
        nettle: 3.6
        opencv-core: 3.4.1_39
        opus: 1.3.1
        p11-kit: 0.23.22
        pciids: 20201127
        pcre: 8.44
        pkg: 1.16.2
        plexmediaserver-plexpass: 1.21.2.3918
        png: 1.6.37
        python37: 3.7.9_1
        readline: 8.0.4_1
        tpm-emulator: 0.7.4_2
        trousers: 0.3.14_3
        wayland: 1.18.0_4
        x265: 3.4_1
        xorgproto: 2020.1
        xvid: 1.3.7,1
Number of packages to be removed: 63
The operation will free 620 MiB.
[tnas720-plex] [1/63] Deinstalling ffmpeg-4.3.1_9,1...
[tnas720-plex] [1/63] Deleting files for ffmpeg-4.3.1_9,1: .......... done
[tnas720-plex] [2/63] Deinstalling gnutls-3.6.15...
[tnas720-plex] [2/63] Deleting files for gnutls-3.6.15: .......... done
[tnas720-plex] [3/63] Deinstalling libass-0.15.0...
[tnas720-plex] [3/63] Deleting files for libass-0.15.0: .......... done
[tnas720-plex] [4/63] Deinstalling libva-2.10.0...
[tnas720-plex] [4/63] Deleting files for libva-2.10.0: .......... done
[tnas720-plex] [5/63] Deinstalling libvdpau-1.4...
pkg: Failed to execute lua script: [string "args = {}..."]:11: attempt to call a nil value (field 'filecmp')
pkg: lua script failed
[tnas720-plex] [5/63] Deleting files for libvdpau-1.4: .......... done
[tnas720-plex] [6/63] Deinstalling harfbuzz-2.7.4...
[tnas720-plex] [6/63] Deleting files for harfbuzz-2.7.4: .......... done
[tnas720-plex] [7/63] Deinstalling libXext-1.3.4,1...
[tnas720-plex] [7/63] Deleting files for libXext-1.3.4,1: .......... done
[tnas720-plex] [8/63] Deinstalling libXfixes-5.0.3_2...
[tnas720-plex] [8/63] Deleting files for libXfixes-5.0.3_2: .......... done
[tnas720-plex] [9/63] Deinstalling p11-kit-0.23.22...
[tnas720-plex] [9/63] Deleting files for p11-kit-0.23.22: .......... done
[tnas720-plex] [10/63] Deinstalling bash-completion-2.11,2...
[tnas720-plex] [10/63] Deleting files for bash-completion-2.11,2: .......... done
[tnas720-plex] [11/63] Deinstalling glib-2.66.4_1,1...
[tnas720-plex] [11/63] Deleting files for glib-2.66.4_1,1: .......... done
[tnas720-plex] [12/63] Deinstalling libX11-1.6.12,1...
[tnas720-plex] [12/63] Deleting files for libX11-1.6.12,1: .......... done
[tnas720-plex] [13/63] Deinstalling trousers-0.3.14_3...
[tnas720-plex] [13/63] Deleting files for trousers-0.3.14_3: .......... done
==> You should manually remove the "_tss" user.
==> You should manually remove the "_tss" group
[tnas720-plex] [14/63] Deinstalling bash-5.1.4_1...
pkg: Failed to execute lua script: [string "shell_path = pkg.prefixed_path("bin/bash")..."]:7: attempt to index a nil value (global 'shell')
[tnas720-plex] [14/63] Deleting files for bash-5.1.4_1: .......... done
[tnas720-plex] [15/63] Deinstalling fontconfig-2.13.92_2,1...
[tnas720-plex] [15/63] Deleting files for fontconfig-2.13.92_2,1: .......... done
[tnas720-plex] [16/63] Deinstalling libdrm-2.4.104,1...
[tnas720-plex] [16/63] Deleting files for libdrm-2.4.104,1: .......... done
[tnas720-plex] [17/63] Deinstalling libidn2-2.3.0_1...
[tnas720-plex] [17/63] Deleting files for libidn2-2.3.0_1: .......... done
[tnas720-plex] [18/63] Deinstalling libtheora-1.1.1_7...
[tnas720-plex] [18/63] Deleting files for libtheora-1.1.1_7: .......... done
[tnas720-plex] [19/63] Deinstalling libxcb-1.14_1...
[tnas720-plex] [19/63] Deleting files for libxcb-1.14_1: .......... done
[tnas720-plex] [20/63] Deinstalling nettle-3.6...
[tnas720-plex] [20/63] Deleting files for nettle-3.6: .......... done
[tnas720-plex] [21/63] Deinstalling python37-3.7.9_1...
[tnas720-plex] [21/63] Deleting files for python37-3.7.9_1: .......... done
[tnas720-plex] [22/63] Deinstalling tpm-emulator-0.7.4_2...
[tnas720-plex] [22/63] Deleting files for tpm-emulator-0.7.4_2: .......... done
[tnas720-plex] [23/63] Deinstalling wayland-1.18.0_4...
[tnas720-plex] [23/63] Deleting files for wayland-1.18.0_4: .......... done
[tnas720-plex] [24/63] Deinstalling freetype2-2.10.4...
[tnas720-plex] [24/63] Deleting files for freetype2-2.10.4: .......... done
[tnas720-plex] [25/63] Deinstalling gettext-runtime-0.21...
[tnas720-plex] [25/63] Deleting files for gettext-runtime-0.21: .......... done
[tnas720-plex] [26/63] Deinstalling gmp-6.2.1...
[tnas720-plex] [26/63] Deleting files for gmp-6.2.1: .......... done
[tnas720-plex] [27/63] Deinstalling libXdmcp-1.1.3...
[tnas720-plex] [27/63] Deleting files for libXdmcp-1.1.3: ......... done
[tnas720-plex] [28/63] Deinstalling libffi-3.3_1...
[tnas720-plex] [28/63] Deleting files for libffi-3.3_1: .......... done
[tnas720-plex] [29/63] Deinstalling libpciaccess-0.16...
[tnas720-plex] [29/63] Deleting files for libpciaccess-0.16: ......... done
[tnas720-plex] [30/63] Deinstalling libtasn1-4.16.0_1...
[tnas720-plex] [30/63] Deleting files for libtasn1-4.16.0_1: .......... done
[tnas720-plex] [31/63] Deinstalling libunistring-0.9.10_1...
[tnas720-plex] [31/63] Deleting files for libunistring-0.9.10_1: .......... done
[tnas720-plex] [32/63] Deinstalling libv4l-1.20.0...
[tnas720-plex] [32/63] Deleting files for libv4l-1.20.0: .......... done
[tnas720-plex] [33/63] Deinstalling libvorbis-1.3.7_2,3...
[tnas720-plex] [33/63] Deleting files for libvorbis-1.3.7_2,3: .......... done
[tnas720-plex] [34/63] Deinstalling readline-8.0.4_1...
[tnas720-plex] [34/63] Deleting files for readline-8.0.4_1: .......... done
[tnas720-plex] [35/63] Deinstalling aom-2.0.1_1...
[tnas720-plex] [35/63] Deleting files for aom-2.0.1_1: .......... done
[tnas720-plex] [36/63] Deinstalling argp-standalone-1.3_4...
[tnas720-plex] [36/63] Deleting files for argp-standalone-1.3_4: ......... done
[tnas720-plex] [37/63] Deinstalling ca_root_nss-3.58...
[tnas720-plex] [37/63] Deleting files for ca_root_nss-3.58: ....... done
[tnas720-plex] [38/63] Deinstalling dav1d-0.8.1...
[tnas720-plex] [38/63] Deleting files for dav1d-0.8.1: .......... done
[tnas720-plex] [39/63] Deinstalling expat-2.2.10...
[tnas720-plex] [39/63] Deleting files for expat-2.2.10: .......... done
[tnas720-plex] [40/63] Deinstalling fribidi-1.0.10...
[tnas720-plex] [40/63] Deleting files for fribidi-1.0.10: .......... done
[tnas720-plex] [41/63] Deinstalling graphite2-1.3.14...
[tnas720-plex] [41/63] Deleting files for graphite2-1.3.14: .......... done
[tnas720-plex] [42/63] Deinstalling indexinfo-0.3.1...
[tnas720-plex] [42/63] Deleting files for indexinfo-0.3.1: .... done
[tnas720-plex] [43/63] Deinstalling jpeg-turbo-2.0.6...
[tnas720-plex] [43/63] Deleting files for jpeg-turbo-2.0.6: .......... done
[tnas720-plex] [44/63] Deinstalling lame-3.100_2...
[tnas720-plex] [44/63] Deleting files for lame-3.100_2: .......... done
[tnas720-plex] [45/63] Deinstalling libXau-1.0.9...
[tnas720-plex] [45/63] Deleting files for libXau-1.0.9: .......... done
[tnas720-plex] [46/63] Deinstalling libepoll-shim-0.0.20201229...
[tnas720-plex] [46/63] Deleting files for libepoll-shim-0.0.20201229: .......... done
[tnas720-plex] [47/63] Deinstalling libiconv-1.16...
[tnas720-plex] [47/63] Deleting files for libiconv-1.16: .......... done
[tnas720-plex] [48/63] Deinstalling libogg-1.3.4,4...
[tnas720-plex] [48/63] Deleting files for libogg-1.3.4,4: .......... done
[tnas720-plex] [49/63] Deinstalling libpthread-stubs-0.4...
[tnas720-plex] [49/63] Deleting files for libpthread-stubs-0.4: .... done
[tnas720-plex] [50/63] Deinstalling libudev-devd-0.4.2_1...
[tnas720-plex] [50/63] Deleting files for libudev-devd-0.4.2_1: ........ done
[tnas720-plex] [51/63] Deinstalling libvpx-1.9.0...
[tnas720-plex] [51/63] Deleting files for libvpx-1.9.0: .......... done
[tnas720-plex] [52/63] Deinstalling libx264-0.161.3020...
[tnas720-plex] [52/63] Deleting files for libx264-0.161.3020: ......... done
[tnas720-plex] [53/63] Deinstalling libxml2-2.9.10_2...
[tnas720-plex] [53/63] Deleting files for libxml2-2.9.10_2: .......... done
[tnas720-plex] [54/63] Deinstalling opencv-core-3.4.1_39...
[tnas720-plex] [54/63] Deleting files for opencv-core-3.4.1_39: .......... done
[tnas720-plex] [55/63] Deinstalling opus-1.3.1...
[tnas720-plex] [55/63] Deleting files for opus-1.3.1: .......... done
[tnas720-plex] [56/63] Deinstalling pciids-20201127...
[tnas720-plex] [56/63] Deleting files for pciids-20201127: ..... done
[tnas720-plex] [57/63] Deinstalling pcre-8.44...
[tnas720-plex] [57/63] Deleting files for pcre-8.44: .......... done
[tnas720-plex] [58/63] Deinstalling pkg-1.16.2...
pkg: Failed to execute lua script: [string "-- args: etc/pkg.conf.sample..."]:12: attempt to call a nil value (field 'filecmp')
[tnas720-plex] [58/63] Deleting files for pkg-1.16.2: .......... done
[tnas720-plex] [59/63] Deinstalling plexmediaserver-plexpass-1.21.2.3918...
[tnas720-plex] [59/63] Deleting files for plexmediaserver-plexpass-1.21.2.3918: .......... done
==> You should manually remove the "plex" user.
==> You should manually remove the "plex" group
[tnas720-plex] [60/63] Deinstalling png-1.6.37...
[tnas720-plex] [60/63] Deleting files for png-1.6.37: .......... done
[tnas720-plex] [61/63] Deinstalling x265-3.4_1...
[tnas720-plex] [61/63] Deleting files for x265-3.4_1: .......... done
[tnas720-plex] [62/63] Deinstalling xorgproto-2020.1...
[tnas720-plex] [62/63] Deleting files for xorgproto-2020.1: .......... done
[tnas720-plex] [63/63] Deinstalling xvid-1.3.7,1...
[tnas720-plex] [63/63] Deleting files for xvid-1.3.7,1: ........ done
Updating plugin artifact...
  - ffmpeg...
WB3FFV
Yea, I caught the typo, but thanks. See my prior message, where I actually ran the iocage commands. This is a new TrueNAS built, started out as a 12.0U1 server, so not even pulled forward from an older FreeNAS build..
Heffy
ThreeDee
Plex via plug in is stuck on 12.1 .. which finally got the better of my OCD
I created a new jail on 12.2 and manually installed via https://www.truenas.com/community/r...darr-lidarr-jackett-transmission-organizr.58/ using the plex-pass version and leaving out the mount points manual creation.
echo '{"pkgs":["plexmediaserver-plexpass","ca_root_nss"]}' > /tmp/pkg.json
iocage create -n "WhateverYouWantToNameYourJail" -p /tmp/pkg.json -r 12.2-RELEASE ip4_addr="vnet0|<IP>/<MASK>" defaultrouter="<GATEWAY>" vnet="on" allow_raw_sockets="1" boot="on"
rm /tmp/pkg.json
iocage exec <NameOfYourJail> sysrc "plexmediaserver_plexpass_enable=YES"
iocage exec <NameOfYourJail> service plexmediaserver_plexpass start
then ..
pkg install wget
..then to keep plex up to date ..
wget https://raw.githubusercontent.com/mstinaff/PMS_Updater/master/PMS_Updater.sh
sh PMS_Updater.sh -v -a
I had one little hiccup with plex not starting after adding mount points via the web gui..but going into host shell and re-running
got it restarting on it's own again ..
