Hey All,
Hopefully Someone can assist. I have previously had Truenas running fine on this hardware but now i cannot install any plugins or create a jail. I get the following error when trying to install plugin,
Error: HTTPSConnectionPool(host='download.freebsd.org', port=443): Max retries exceeded with url: /ftp/releases/amd64 (Caused by SSLError(SSLError("bad handshake: Error([('SSL routines', 'tls_process_server_certificate', 'certificate verify failed'
I get a similar error when trying to create a Jail,
I have set static IPs for Plex and set DNS and Gateway (All settings are the same as previous when TrueNas and Plex worked last), re installed. I can also ping anything from shell.
Not sure what steps to take next.
Thank You
Thank You
