Plugins>Available: Some error occurred
ric
If i navigate to Plugins>Available menu, It throws below error message. Running the latest Freenas 11.2-stable - Release Train
Error: concurrent.futures.process._RemoteTraceback:
File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_plugin.py", line 1269, in _clone_repo
repo = git.Repo(destination)
File "/usr/local/lib/python3.6/site-packages/git/repo/base.py", line 124, in __init__
raise NoSuchPathError(epath)
git.exc.NoSuchPathError: /mnt/tank/iocage/.plugin_index
File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_plugin.py", line 636, in __clone_pull_plugin_index
self._clone_repo(self.branch, git_server, git_working_dir, callback=self.callback)
File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_plugin.py", line 1307, in _clone_repo
k: v for k, v in kwargs.items() if v
File "/usr/local/lib/python3.6/site-packages/git/repo/base.py", line 982, in clone_from
return cls._clone(git, url, to_path, GitCmdObjectDB, progress, **kwargs)
File "/usr/local/lib/python3.6/site-packages/git/repo/base.py", line 933, in _clone
finalize_process(proc, stderr=stderr)
File "/usr/local/lib/python3.6/site-packages/git/util.py", line 336, in finalize_process
proc.wait(**kwargs)
File "/usr/local/lib/python3.6/site-packages/git/cmd.py", line 418, in wait
raise GitCommandError(self.args, status, errstr)
git.exc.GitCommandError: Cmd('git') failed due to: exit code(128)
cmdline: git clone -v https://github.com/freenas/iocage-ix-plugins.git /mnt/tank/iocage/.plugin_index
stderr: 'Cloning into '/mnt/tank/iocage/.plugin_index'...
error: chmod on /mnt/tank/iocage/.plugin_index/.git/config.lock failed: Operation not permitted
fatal: could not set 'core.filemode' to 'false'
File "/usr/local/lib/python3.6/concurrent/futures/process.py", line 175, in _process_worker
r = call_item.fn(*call_item.args, **call_item.kwargs)
File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 133, in main_worker
res = loop.run_until_complete(coro)
File "/usr/local/lib/python3.6/asyncio/base_events.py", line 484, in run_until_complete
return future.result()
File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 93, in _run
return await self._call(name, serviceobj, methodobj, params=args, job=job)
File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 85, in _call
return methodobj(*params)
File "/usr/local/lib/python3.6/site-packages/middlewared/schema.py", line 668, in nf
return f(*args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/jail.py", line 544, in list_resource
header=False)
File "/usr/local/lib/python3.6/site-packages/iocage_lib/iocage.py", line 914, in fetch
icon=True, official=official)
File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_plugin.py", line 654, in fetch_plugin_index
self.__clone_pull_plugin_index()
File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_plugin.py", line 643, in __clone_pull_plugin_index
_callback=self.callback)
File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_common.py", line 90, in logit
_callback(content, exception)
File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_common.py", line 64, in callback
raise callback_exception(message)
RuntimeError: Cmd('git') failed due to: exit code(128)
The above exception was the direct cause of the following exception:
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 165, in call_method
result = await self.middleware.call_method(self, message)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1096, in call_method
return await self._call(message['method'], serviceobj, methodobj, params, app=app, io_thread=False)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1041, in _call
return await self._call_worker(name, *args)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1061, in _call_worker
return await self.run_in_proc(main_worker, name, args, job)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 995, in run_in_proc
return await self.run_in_executor(self.__procpool, method, *args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 971, in run_in_executor
