Hey guys and gals,
I was going to look for plugins for my FreeNas, mainly one that would work like a personal cloud service... when i came across this error code. I'm still new to Freenas, I've only had my build for a month or so. What did I do to cause this? and how can I recover from it?
[Errno 1] Operation not permitted: b'/mnt/Server/iocage/.plugin_index/couchpotato.json'
Error: concurrent.futures.process._RemoteTraceback:
File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_plugin.py", line 643, in fetch_plugin_index
self.__clone_repo(git_server, git_working_dir)
File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_plugin.py", line 1255, in __clone_repo
porcelain.pull(destination, repo_url, errstream=devnull)
File "/usr/local/lib/python3.6/site-packages/dulwich/porcelain.py", line 826, in pull
r.reset_index(tree=tree)
File "/usr/local/lib/python3.6/site-packages/dulwich/repo.py", line 950, in reset_index
validate_path_element=validate_path_element)
File "/usr/local/lib/python3.6/site-packages/dulwich/index.py", line 530, in build_index_from_tree
obj, entry.mode, full_path, honor_filemode=honor_filemode)
File "/usr/local/lib/python3.6/site-packages/dulwich/index.py", line 460, in build_file_from_blob
os.chmod(target_path, mode)
PermissionError: [Errno 1] Operation not permitted: b'/mnt/Server/iocage/.plugin_index/couchpotato.json'
File "/usr/local/lib/python3.6/concurrent/futures/process.py", line 175, in _process_worker
r = call_item.fn(*call_item.args, **call_item.kwargs)
File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 133, in main_worker
res = loop.run_until_complete(coro)
File "/usr/local/lib/python3.6/asyncio/base_events.py", line 484, in run_until_complete
return future.result()
File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 93, in _run
return await self._call(name, serviceobj, methodobj, params=args, job=job)
File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 85, in _call
return methodobj(*params)
File "/usr/local/lib/python3.6/site-packages/middlewared/schema.py", line 668, in nf
return f(*args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/jail.py", line 540, in list_resource
header=False)
File "/usr/local/lib/python3.6/site-packages/iocage_lib/iocage.py", line 914, in fetch
icon=True, official=official)
File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_plugin.py", line 650, in fetch_plugin_index
_callback=self.callback)
File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_common.py", line 90, in logit
_callback(content, exception)
File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_common.py", line 64, in callback
raise callback_exception(message)
RuntimeError: [Errno 1] Operation not permitted: b'/mnt/Server/iocage/.plugin_index/couchpotato.json'
The above exception was the direct cause of the following exception:
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 167, in call_method
result = await self.middleware.call_method(self, message)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1098, in call_method
return await self._call(message['method'], serviceobj, methodobj, params, app=app, io_thread=False)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1043, in _call
return await self._call_worker(name, *args)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1063, in _call_worker
return await self.run_in_proc(main_worker, name, args, job)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 997, in run_in_proc
return await self.run_in_executor(self.__procpool, method, *args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 973, in run_in_executor
