Plugin stopped after upgrade to 11.1
Pcovell74
I finally did the upgrade to 11.1 from 9.10. After doing so 3 of my 5 plugins will not restart.
Transmission
Couch potato
OwnCloud
Where do I start to investigate why these three plugins will not start?
Thanks,
Preston
nojohnny101
you can look at /var/log/messages.
it is generally recommended to save necessary setting files and databases then rebuild jails.
Pcovell74
Mar 17 09:27:33 FreeNAS02 uwsgi: jexec 6 /usr/pbi/transmission-amd64/control start 10.0.20.4 12354
Mar 17 09:27:48 FreeNAS02 uwsgi: [plugins.utils:88] Couldn't retrieve http://10.0.1.12/plugins/transmission/3/_s/status: timed out
Mar 17 09:27:49 FreeNAS02 uwsgi: [plugins.utils:88] Couldn't retrieve http://10.0.1.12/plugins/owncloud/5/_s/status: timed out
Mar 17 09:27:49 FreeNAS02 uwsgi: [plugins.utils:88] Couldn't retrieve http://10.0.1.12/plugins/couchpotato/4/_s/status: timed out
Mar 17 09:28:07 FreeNAS02 uwsgi: [freeadmin.navtree:561] Couldn't retrieve http://10.0.1.12/plugins/owncloud/5/_s/treemenu: timed out
Mar 17 09:28:07 FreeNAS02 uwsgi: [freeadmin.navtree:561] Couldn't retrieve http://10.0.1.12/plugins/couchpotato/4/_s/treemenu: timed out
Mar 17 09:28:07 FreeNAS02 uwsgi: [freeadmin.navtree:561] Couldn't retrieve http://10.0.1.12/plugins/transmission/3/_s/treemenu: timed out
Mar 17 10:33:17 FreeNAS02 uwsgi: [freeadmin.navtree:561] Couldn't retrieve http://10.0.1.12/plugins/transmission/3/_s/treemenu: timed out
Mar 17 10:33:17 FreeNAS02 uwsgi: [freeadmin.navtree:561] Couldn't retrieve http://10.0.1.12/plugins/owncloud/5/_s/treemenu: timed out
Mar 17 10:33:17 FreeNAS02 uwsgi: [freeadmin.navtree:561] Couldn't retrieve http://10.0.1.12/plugins/couchpotato/4/_s/treemenu: timed out
Mar 17 10:33:23 FreeNAS02 uwsgi: [freeadmin.navtree:561] Couldn't retrieve http://10.0.1.12/plugins/couchpotato/4/_s/treemenu: timed out
Mar 17 10:33:23 FreeNAS02 uwsgi: [freeadmin.navtree:561] Couldn't retrieve http://10.0.1.12/plugins/transmission/3/_s/treemenu: timed out
Mar 17 10:33:23 FreeNAS02 uwsgi: [freeadmin.navtree:561] Couldn't retrieve http://10.0.1.12/plugins/owncloud/5/_s/treemenu: timed out
Mar 17 10:42:13 FreeNAS02 uwsgi: [freeadmin.navtree:561] Couldn't retrieve http://10.0.1.12/plugins/couchpotato/4/_s/treemenu: timed out
Mar 17 10:42:13 FreeNAS02 uwsgi: [freeadmin.navtree:561] Couldn't retrieve http://10.0.1.12/plugins/transmission/3/_s/treemenu: timed out
Mar 17 10:42:13 FreeNAS02 uwsgi: [freeadmin.navtree:561] Couldn't retrieve http://10.0.1.12/plugins/owncloud/5/_s/treemenu: timed out
Mar 17 10:48:02 FreeNAS02 uwsgi: [plugins.utils:88] Couldn't retrieve http://10.0.1.12/plugins/transmission/3/_s/status: timed out
Mar 17 10:48:02 FreeNAS02 uwsgi: [plugins.utils:88] Couldn't retrieve http://10.0.1.12/plugins/couchpotato/4/_s/status: timed out
Mar 17 10:48:03 FreeNAS02 uwsgi: [plugins.utils:88] Couldn't retrieve http://10.0.1.12/plugins/owncloud/5/_s/status: timed out
Mar 17 10:53:32 FreeNAS02 uwsgi: [plugins.utils:88] Couldn't retrieve http://10.0.1.12/plugins/transmission/3/_s/status: timed out
Mar 17 10:53:32 FreeNAS02 uwsgi: [plugins.utils:88] Couldn't retrieve http://10.0.1.12/plugins/owncloud/5/_s/status: timed out
Mar 17 10:53:33 FreeNAS02 uwsgi: [plugins.utils:88] Couldn't retrieve http://10.0.1.12/plugins/couchpotato/4/_s/status: timed out
I have checked and there is a gateway on all the plugins. but still cant ping the gateway or itself.
nojohnny101
Honestly I think most responses you'll get on here is to rebuild the jails. These are old warden once correct? The new plugin/jail system was completely redesigned for FN 11. You're asking for more headaches trying to keep non-supported jails around.
Pcovell74
Is there anyway to re-create a new NIC for the jail? The Jail is running but not routing. Tested in the terminal. IFCONFIG shows no IP address.
Setting up Transmission and Couchpotato was a pain to start with so if I can just repair it, I will try.
Same with Owncloud, I have had it setup for a long time. I was going to migrate to NextCloud eventually but I have users with data on this Jail.
So is there anyway to make the Jail recreate a new virtual NIC?
