Plugin menu empty
Willem1987
Hello All,
I have had the plugins working propertly before, but somehow something went wrong. The plugins menu doesn't load and when i refresh the admin console i see errors flow in the console in the bottom of the page. I am unfortunately still quite the bsd Noob. I have checked the var/log/messages (in the jail) but it seems it does not always update messages there?
I have looked through the folders a lot, but i cannot quite figure out how the status service in the plugins works. The status url is based on the freenas ip, while it seems to connect to a fastcgi jail ip, with specific port.
I have tried restarting the server itself a few times and restarted the individual services (through service sabnzbd restart). My main problem is, that i have not found a way to diagnose my problems. I checked the nginx error log outside the jail and the messages inside the jail. But the logs i find are all very limited.
I hope someone can help me find the right track.
I read the forum rules and have found some similar posts to my problem, but some seemed unanswered while anothed said the 4th reboot was the charm. So i decided to open my own thread. Below is some required info. I suspect it is mostly a software/config error, but i added the hardware just to be safe.
1. My Freenas version: FreeNAS-8.3.1-RELEASE-p2-x64
2. Hardware:
ASRock B75 Pro3-M (Socket 1155)B75 PRO3-M
Intel Core i3 3220T (Socket 1155)BX80637I33220T
Crucial 8GB PC3-12800 DDR3 SDRAM Ballistix (2x 4GB, 1600MHz)BLS2CP4G3D1609DS1S00CEU
3. Error
Jul 26 20:43:57 freenas manage.py: [plugins.utils:71] Couldn't retrieve http://192.168.1.2/plugins/sabnzbd/_s/status: HTTP Error 502: Bad Gateway
Jul 26 20:43:57 freenas manage.py: [plugins.utils:71] Couldn't retrieve http://192.168.1.2/plugins/couchpotato/_s/status: HTTP Error 502: Bad Gateway
Jul 26 20:43:57 freenas manage.py: [plugins.utils:71] Couldn't retrieve http://192.168.1.2/plugins/sickbeard/_s/status: HTTP Error 502: Bad Gateway
Jul 26 20:43:57 freenas manage.py: [plugins.utils:71] Couldn't retrieve http://192.168.1.2/plugins/headphones/_s/status: HTTP Error 502: Bad Gateway
Jul 26 20:43:57 freenas manage.py: [plugins.utils:71] Couldn't retrieve http://192.168.1.2/plugins/transmission/_s/status: HTTP Error 502: Bad Gateway
Jul 26 20:43:57 freenas manage.py: [plugins.utils:71] Couldn't retrieve http://192.168.1.2/plugins/gamez/_s/status: HTTP Error 502: Bad Gateway
Willem1987
For the record... The plugins themselves seem to run alright. It's just that i can't figure out why the menu won't work and i am not finding any errors in the log. When i try starting plugins from the GUI i get the Message:
Some error occurred​
I currently have installed:
Sabnzbd 7.14
Sickbeard fb37d332b333b43e7bcae46b619ae6b7ef94e266
Headphones
c0cbe6fe0e3c7aa6e084a87cb29d2e2622eb9964​
Gamez (can't find version...)
transmission 2.77
Couchpotato fc8db130e02b8b6475a95e6725dc5dfa4926c645 (15-7-2013 12:17:17)
Recently i installed python27 port to get git to work.
Also i have apache22, php5, and mysql running in the jail to run a newznab server.
Willem1987
First trouble i eventually found is that i changed hostname to jailserver in rc.conf. This seemed to cause some trouble to the jail plugin.
I installed another plugin today and it did show up in plugin menu. After examining the rc.conf while stopping and starting plugins i noticed the plugins add a line to say a plugin is enabled. My sabnzbd already had this line even while turned off. This seemed to cause some trouble although i am not sure i am in the clear now.
