Hey guys,
I've got an odd problem with FreeNas. Last night I replaced a power cable that had come a little loose in my server, and upon rebooting I find that the plugins menu is empty! I can still access my plugins via HTTP and they're running as per normal, but FreeNas doesn't detect this.
Output from jls:
Now, every other time I've done this JID has been 1. Does this have any impact on what FreeNas is programmed to detect?
I can see the following log entries in /var/log/messages
whenver I attempt to access FreeNas web interface.
The only other thing I have running inside the jail is a mysql server. It's been running like this for nearly 10 months without issue, so this is a little odd. I haven't changed any settings recently either.
What's the go?
Thanks.
Output from jls:
JID IP Address Hostname Path
2 - software /mnt/storage/jail/software
Apr 11 21:00:07 TheServer manage.py: [freeadmin.navtree:416] Couldn't retrieve http://192.168.1.8/plugins/sabnzbd/_s/treemenu: HTTP Error 502: Bad Gateway Apr 11 21:00:07 TheServer manage.py: [freeadmin.navtree:416] Couldn't retrieve http://192.168.1.8/plugins/sickbeard/_s/treemenu: HTTP Error 502: Bad Gateway Apr 11 21:00:07 TheServer manage.py: [freeadmin.navtree:416] Couldn't retrieve http://192.168.1.8/plugins/couchpotato/_s/treemenu: HTTP Error 502: Bad Gateway Apr 11 21:00:07 TheServer manage.py: [freeadmin.navtree:416] Couldn't retrieve http://192.168.1.8/plugins/gamez/_s/treemenu: HTTP Error 502: Bad Gateway Apr 11 21:00:07 TheServer manage.py: [freeadmin.navtree:416] Couldn't retrieve http://192.168.1.8/plugins/transmission/_s/treemenu: HTTP Error 502: Bad Gateway
What's the go?
Thanks.
