PlexMediaServer plugin start problem
Evertb1
Giving up on the idea that my freenas box should only be a file server I decided to install the PlexMediaServer plugin. I have used the web GUI to install it. However after installation I could not start the plugin.
There were three things I noted:
1) The console output showed timeouts on the URL of the Freenas box: See screenshot2
2) Opening the shell of the jail I got an error on pinging the Freenas box see
ping: sendto: Network is unreachable
Clearly some or other network problem. Looking at the configuration of the jail I noted that the jail had a fixed IP adres (192.168.0.1). I also noted that there was an option to get an IP adres by DHCP. I cleared the field with the fixed IP adres and ticked the DHCP option. A restart of the jale took care of getting a new IP adres. And yes The plugin started ot once and every GUI function related to the jail and the plugin was far more responsive.
I am left with a couple of questions:
Do I need to give the jail a fixed IP adres form my DHCP server?
Why is by default a fixed adres assigned while this lead to problems?i
m0nkey_
Please post the output of ifconfig on both the jail and the FreeNAS host. When pasting, please use the [ code ] tags.
Evertb1
My first reaction was: Don't you mean ipconfig? But it's high time I learn a bit more about the Unix commando's. Here are both outputs. The jail is getting it's IP from the DHCP service of my router.
Ifconfig output of the jail:
		options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6>
		inet6 ::1 prefixlen 128
		inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
		groups: lo
epair0b: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
		options=8<VLAN_MTU>
		ether e6:82:3f:67:a7:82
		inet 192.168.178.28 netmask 0xffffff00 broadcast 192.168.178.255
		status: active
		groups: epair
ifconfig output of the freenas host:
igb0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
		options=6403bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,VLAN_HWTSO,RXCSUM_IPV6,TXCSUM_IPV6>
		ether 0c:c4:7a:aa:66:d8
		media: Ethernet autoselect
		status: no carrier
igb1: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
		options=2400b9<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,VLAN_HWTSO,RXCSUM_IPV6>
		ether 0c:c4:7a:aa:66:d9
		inet 192.168.178.40 netmask 0xffffff00 broadcast 192.168.178.255
		media: Ethernet autoselect (1000baseT <full-duplex>)
		status: active
		inet6 fe80::1%lo0 prefixlen 64 scopeid 0x3
		groups: lo
		ether 02:31:7b:f3:63:00
		groups: bridge
		member: epair0a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
				ifmaxaddr 0 port 5 priority 128 path cost 2000
		member: igb1 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
				ifmaxaddr 0 port 2 priority 128 path cost 55
epair0a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
		options=8<VLAN_MTU>
		ether 02:ff:e0:00:05:0a
		nd6 options=1<PERFORMNUD>
		status: active
		groups: epair
motostu
I had the exact same problem. I gave up and left it as DHCP, but ensured the address will not change by reserving it in my DHCP server. I'll be interested in what the solution is, because I compared the ifconfig between a static IP jail and a DHCP jail and could find no difference, other than the IP address.
Sent from my XT1575 using Tapatalk
Evertb1
Well, I have put the problem on the backburner for the moment because there have been some other problems to handle. I have been busy with using a Zyxel NAS as rsync server for the Freenas box. But that had an rsync implementation that was far from complete (zyxel put up its own brand of rsync called zsync). Not to speak about the bad SSH implementation. Luckely it's almost handled with the good use of some third party plug-ins and it looks like I have my rsync tasks running almost OK. I still need to fugure some things out about the attributes on the transferred files and directories. As soon as I am satisfied with it I come back to that Plex plugin. I removed it for now so I can give it a fresh start.
Evertb1
After reinstalling Plex (for the third time) it is running now. I am not out of trouble yet but the problems I see now are more specific. So I close this thread as solved and start another thread.
