So it took me 10sec to find this answer an google. When you click a show to record it you set the "add to library" and this is just the normal path you have setup.
What library do you save your recordings to and then look up what path that library uses. Try looking it up for yourself next time, it's really easy. If not what problem are you having with that process?
