lonewolf
- Mar 13, 2015
Thanks for taking the time to read my problem, I'm currently going through the steps on this guide - https://forums.freenas.org/index.php?threads/how-to-install-plexconnect-for-atv.18315/
When I reach the command 'git clone https://github.com/iBaa/PlexConnect.git' I recive this message
Shared object "libexpat.so.1" not found, required by "git-remote-https"
I've something similar happen recently with libconv.so.2 and I was advised to use 'pkg install libconv' which solved my problem however when using the command 'pkg install libexpat' thinking it would work it came back with this message :-
'pkg: No packages available to install matching 'libexpat' have been found in the
repositories'
As I'm still learning to use freenass, shell and jails any help you can offer will be greatly appreciated.
BuildFreeNAS-9.3-STABLE-201503120630
PlatformAMD A8-6600K APU with Radeon(tm) HD Graphics
Memory 7333 MB
one 2TB drive
1 volume set in stripe layout
plex & transmission with openvpn plugins/jail
repositories'
Memory 7333 MB
one 2TB drive
