traxinv, I tried this and verified that python version 2.7 is running. Still, I get the same response trying to execute the PlexConnect.py script. BTW, inspecting the script more PlexConnect.py) shows a call to '#!/usr/bin/env python', but I am not sure that is where Python is actually located. From the webgui I use the Display System Processes it shows Python2.7 running. Shouldn't the Python script (I'm not programmer, mind you) be calling on python2.7, and not python?
${PYTHON} ${PROGRAM} --pidfile ${PID_FILE}This is a very noob question but I do not understand this part in the steps "We must edit the PlexConnect_daemon.bash so that it explicitly references the python instance". If someone could explain what I am suppose to do to this line that would be awesome!
Code:${PYTHON} ${PROGRAM} --pidfile ${PID_FILE}
PYTHON="/usr/local/bin/python2.7"
Code:PYTHON="/usr/local/bin/python2.7"
Thanks for this awesome write up!
Does this still work for 9.3?
I was trying to recreate (to rename an old jail and get latest version of PlexConnect) and get the following error when I try and download from git
Code:Shared object "libiconv.so.2" not found, required by "git"
Did you manage to get passed this ? I had the same problem and a forum user said to "pkg install libconv" this solved my issue.
Ive become stuck on the command -
- git clone https://github.com/iBaa/PlexConnect.git
and come back with this error - Shared object "libexpat.so.1" not found, required by "git-remote-https"
i tried 'pkg install libexpat' which comes back with -no packages available to install.
Anyone have advice ?
Hi lonewolf,
Looks like the the dependent packages for git was not properly installed. Just a quick question. Did you follow the setup guide step by step? Also when you installed the git package did it give any warnings?
I just tested it on my side. Scratch 9.3 jail and everything works fine.
I would suggest deleting the jail and starting again. Make sure the jail type is the same.
Let me know if you get stuck again?
I did as you advised and deleted the jail then started fresh and it worked i got it to run, however when I'm adding the profile on my aTV i get an error
'an error occurred while adding the profile [-1004] check the url and try again'
I'm using this method for the profile 'http://[plexconnect ip address]/trailers.cer'
Did you remember to change the apple tv's DNS address to the plexconnect jails ip address?
Also. You have have to use this url as the profile:
Http://trailers.apple.com/trailers.cer you must not use the plex connect ip address as the url.
Ok i used the URL you said and it says adding profile however it seems to be stuck with a loading wheel turning infinity it seems. does adding a profile take a while ?
I thought the same :/ i did a couple searches and there doesn't seem to be anyone with similar problemsMmm... Should only take a few seconds...
