Plex plug in is running, but I can't find it...
Paul Lupa
I'm running PMS as a plug in, I do have 'plexpass' and it's working, but when I look for it under jails/plug-ins/vm I don't see it. But it is running!?
Here's the process
/usr/pbi/plexmediaserver-amd64/bin/python2.7
It seems that the old configuration is in
/mnt/XXXXX/jails/.plexmediaserver_1.meta/...
Is this problem due to my upgrading to 11.2 or because of plexpass?
Info:
+ FreeNAS-11.2-RC1 (c831a6a98) @1542148704 +
Operating system type: FreeBSD
Operating system release: 11.2-STABLE
Operating system revision: 199506
Kernel version: FreeBSD 11.2-STABLE #0 r325575+97f4f541349(freenas/11.2-stable): Wed Oct 17 18:06:49 EDT 2018
root@nemesis.tn.ixsystems.com:/freenas-11.2-releng/freenas/_BE/objs/freenas-11.2-releng/freenas/_BE/os/sys/FreeNAS.amd64
Hostname: xxx.xxx.xxx
Name of kernel file booted: /boot/kernel/kernel
debug finished in 0 seconds for FreeNAS-11.2-RC1 (c831a6a98)
kdragon75
Run warden list from a shell. I'm guessing you will see it there.
kdragon75
The new UI will not show the old Warden jails, only the new iocage ones.
kdragon75
Also, there is no security reason to XX out your pool name or you host name.
