Plex not working after upgrade from GUI - version 0.9.12.4.1192
tehmole
Hi everyone,
i updated my plex from 0.9.11.x.x to 0.9.12.4.1192 through GUI/Plugins/installed - i clicked upgrade and left the room - once i came back, it looked like it finished. I looked at the plugins and plex showed the new version but services were turned off. when i tried to turn on service it showed - some error occurred. here's what i see in 'messages' :
Jul 18 22:00:58 freenas notifier: nginx: the configuration file /usr/local/etc/n
ginx/nginx.conf syntax is ok
Jul 18 22:00:58 freenas notifier: nginx: configuration file /usr/local/etc/nginx
/nginx.conf test is successful
Jul 18 22:00:58 freenas epair1a: Ethernet address: 02:1a:7e:00:0d:0a
Jul 18 22:00:58 freenas epair1b: Ethernet address: 02:1a:7e:00:0e:0b
Jul 18 22:00:58 freenas kernel: epair1a: link state changed to UP
Jul 18 22:00:58 freenas kernel: epair1b: link state changed to UP
Jul 18 22:00:58 freenas kernel: epair1a: promiscuous mode enabled
Jul 18 22:00:58 freenas kernel: ng_ether_ifnet_arrival_event: can't re-name node
epair1b
epair1b
Jul 18 22:01:07 freenas manage.py: [plugins.utils:92] Couldn't retrieve http://1
92.168.1.222/plugins/plexmediaserver/1/_s/status: No JSON object could be decode
d
I tried restarting Jail and Freenas (FreeNAS-9.3-STABLE-201501162230)
can someone please help.
Thank you
Joshua Parker Ruehlig
Hi everyone,
epair1b
epair1b
d
Thank you
Can you try restarting the plex jail. A few versions ago I updating some of the plugin code which would require the plugin middleware layer (the one who responds to that status URL) to be restarted.
Hi Joshua, yes i've restarted jail and the entire server.
sorry, didn't read thoroughly enough.
can you try running this in the plex jail.
service plexmediaserver onestart
if you can still reach plex then you should decide if starting it from the plugins tab is important to you. if so, I can list the steps to restore your current plex metadata to a new jail.
tehmole
please Joshua - kids are crawling my neck cause they can't watch 'Frozen'.......
i believe restoring plex metadata to a new jail will be the easiest and fastest?
side note - using plex streamed from Roku.
Ohh no, ok time to work fast then, lol.
* Install a new instance of plex
* Copy over the data-directory, editing the below according to your jail paths
cp -R /mnt/tank/jails/plexmediaserver_1/var/db/plexdata /mnt/tank/jails/plexmediaserver_2/var/db/plexdata
chown -R 972:972 /mnt/tank/jails/plexmediaserver_2/var/db/plexdata
* Delete the first plex plugin from the Plugins > Installed tab
* (optional) Change the IP of the remaining plex plugin on the Jails tab
* start the remaining instance of plex
tehmole
worked out well - had to put back all the mnt's ... but it's working nicely.........didn't get my head chewed off by the kids.
