pinoli
- Feb 20, 2021
I have been searching for this specific problem in the TrueNAS SCALE forum but I could not find anything.
I found some reference about the same problem for TrueNAS CORE that was not helpful.
I am running TrueNAS SCALE Angelfish 21.01 ALPHA on the hardware in signature (ask if you need more info).
I tried the official Plex app, provided the claim token, mounted a SMB share to
I can access to the web portal by using the PORTAL button on the deployed app in the Installed Apps section of TrueNAS, I can login into Plex and authorize the new server (plex.tv shows the local IP of the server and asks me if I want to authorize the connection).
At this point I am greeted with the infamous
I am kind of lost, since the suggestion I have seen here does not apply to me, because I don't have the Network section in my Plex web UI.
Also, I connected to the pod using the Shell feature of apps in TrueNas SCALE, but I can't seem to find where Plex settings are located.
I found binaries in
Thanks in advance for any help.
/media
folder, assigned the Intel GPU for HW accelaration and finally deployed.I can access to the web portal by using the PORTAL button on the deployed app in the Installed Apps section of TrueNAS, I can login into Plex and authorize the new server (plex.tv shows the local IP of the server and asks me if I want to authorize the connection).
No soup for you!
The server you're trying to access doesn't want to let you in. Make sure you're signed in as a user with access to this server.
I found binaries in
/usr/lib/plexmediaserver
and service scripts in /var/run/s6/services/plex
, but preferences.xml is nowhere to be found.Thanks in advance for any help.
