plex installation stuck
I'm trying to re-install plex media server. I had been trying to deal with an issue with the media folder not showing up and decided to do a "fresh" install of plex. I first uninstalled, then attempted to re-install via the plugins page (default settings). It has been stuck on 50.00% - ffmpeg for about 2 hours at this point. I've had plex on this system before (for about 2 years at this point), so it should work.
Currently the only error I'm getting from the interactive console during the install is: "kernel: in6_purgeaddr: err=65, destination address delete failed"
I tried opening up another GUI window, and I can see plex as an installed plugin. I tried restarting the service but that pop-up locks/loops as well and then plex disappears as an installed plugin. (same happens with restart command)
As a quick test, I decided to install another iX plugin to see if this was generalizable or just on plex. Tried minio and the installation proceeded fine.
Any help would be greatly appreciated!
Cheers,
Ben
