Hi everyone,
I'm new to this board and decided to move my Plex Server to my TrueNas system. I started with adding the plugin, which worked to the point I need to find info. I came across this awesome post: https://www.truenas.com/community/threads/dns-error-when-trying-to-install-plex.109336/#post-756433 and found that plugins are a dead man walking. I killed my Plex plugin and jail and went with these suggestions. I then followed the instructions and used the danb35 script which seemed to work to perfection, as I can see the jail, and the shell confirmed it installed Plex. I created a config file as below:
JAIL_IP="192.168.1.131"
DEFAULT_GW_IP="192.168.1.1"
POOL_PATH="/mnt/archive"
I went to the http://192.168.1.131:32400/web, (the link came up in the shell so I just clicked it), and it doesn't connect. I copied and pasted the link and still the same.
I know the plex data directory was created in the mount point because I can cd to that directory in the shell.
I expect to see a blank Plex Server running, as I have not added media directory, and will do so after I do some more reading on the forum. I know I didn't do something correctly and any guidence would be appreicated.
Thanks to everyone in advance.
Specs in the signature.
mmadd29
mmadd29
