Plex GUI: "This page isn’t working" / Need help troubleshooting
thepixelgeek
Need help troubleshooting. Plex worked fine after installing it, but after a day or so I lose connection.
Iocage console shows plex Jail is "up".
Basic Properties show checked DHCP, VNET and BPF.
Network Properties show: interfaces vnet0:bridge0
Plex gui at http://192.168.4.97:32400/web/index.html
Gateway at: http://192.168.4.1
Perhaps due to dhclient connection closed? Or, igb0: link state changed to DOWN?
Log Messages:
Jan 20 17:03:32 plex newsyslog[31263]: logfile first created
Jan 20 17:03:32 plex syslogd: kernel boot file is /boot/kernel/kernel
Jan 20 17:03:40 plex pkg-static: pkg-1.12.0 installed
Jan 20 17:03:41 plex pkg-static: pkg reinstalled: 1.12.0 -> 1.12.0
Jan 20 17:03:53 plex pkg: plexmediaserver-plexpass-1.18.3.2129 installed
Jan 20 17:03:54 plex pkg: ca_root_nss-3.49.1 installed
Jan 21 01:03:54 plex dhclient[30960]: connection closed
Jan 21 01:03:54 plex dhclient[30960]: exiting.
Jan 20 17:03:54 plex syslogd: exiting on signal 15
Jan 20 17:04:08 plex syslogd: kernel boot file is /boot/kernel/kernel
Jan 20 17:19:49 plex pkg: plexmediaserver-plexpass upgraded: 1.18.3.2129 -> 1.18.4.2171
Jan 20 17:20:17 plex dhclient[31758]: connection closed
Jan 20 17:20:17 plex dhclient[31758]: exiting.
Jan 20 17:20:17 plex syslogd: exiting on signal 15
Jan 20 17:20:34 plex syslogd: kernel boot file is /boot/kernel/kernel
Jan 20 18:27:17 plex dhclient[38874]: connection closed
Jan 20 18:27:17 plex dhclient[38874]: exiting.
Jan 20 18:27:17 plex syslogd: exiting on signal 15
Jan 20 18:27:27 plex syslogd: kernel boot file is /boot/kernel/kernel
Jan 30 08:33:11 plex syslogd: exiting on signal 15
Jan 30 08:44:01 plex syslogd: kernel boot file is /boot/kernel/kernel
Feb 12 11:32:25 plex syslogd: exiting on signal 15
Feb 12 12:08:42 plex syslogd: kernel boot file is /boot/kernel/kernel
Feb 12 12:11:03 plex syslogd: exiting on signal 15
Feb 16 12:36:24 plex syslogd: kernel boot file is /boot/kernel/kernel
Feb 17 05:01:51 plex syslogd: exiting on signal 15
Feb 17 05:36:32 plex syslogd: kernel boot file is /boot/kernel/kernel
dmesage.yesterday
pcib3: <ACPI PCI-PCI bridge> irq 16 at device 28.0 on pci0
pci3: <ACPI PCI bus> on pcib3
pcib4: <ACPI PCI-PCI bridge> irq 16 at device 29.0 on pci0
pci4: <ACPI PCI bus> on pcib4
igb0: <Intel(R) PRO/1000 Network Connection, Version - 2.5.3-k> port 0xd000-0xd01f mem 0xdf200000-0xdf27ffff,0xdf280000-0xdf283fff irq 16 at device 0.0 on pci4
igb0: Using MSIX interrupts with 5 vectors
igb0: Ethernet address: 0c:c4:7a:86:65:c4
igb0: Bound queue 0 to cpu 0
igb0: Bound queue 1 to cpu 1
igb0: Bound queue 2 to cpu 2
igb0: Bound queue 3 to cpu 3
pcib5: <ACPI PCI-PCI bridge> irq 17 at device 29.1 on pci0
pci5: <ACPI PCI bus> on pcib5
igb1: <Intel(R) PRO/1000 Network Connection, Version - 2.5.3-k> port 0xc000-0xc01f mem 0xdf100000-0xdf17ffff,0xdf180000-0xdf183fff irq 17 at device 0.0 on pci5
igb1: Using MSIX interrupts with 5 vectors
igb1: Ethernet address: 0c:c4:7a:86:65:c5
igb1: Bound queue 0 to cpu 4
igb1: Bound queue 1 to cpu 5
igb1: Bound queue 2 to cpu 6
igb1: Bound queue 3 to cpu 7
pcib6: <ACPI PCI-PCI bridge> irq 18 at device 29.2 on pci0
pci6: <ACPI PCI bus> on pcib6
pcib7: <ACPI PCI-PCI bridge> at device 0.0 on pci6
pci7: <ACPI PCI bus> on pcib7
vgapci0: <VGA-compatible display> port 0xb000-0xb07f mem 0xde000000-0xdeffffff,0xdf000000-0xdf01ffff irq 18 at device 0.0 on pci7
vgapci0: Boot video device
isab0: <PCI-ISA bridge> at device 31.0 on pci0
isa0: <ISA bus> on isab0
pci0: <memory> at device 31.2 (no driver attached)
acpi_button0: <Sleep Button> on acpi0
acpi_button1: <Power Button> on acpi0
acpi_tz0: <Thermal Zone> on acpi0
acpi_tz1: <Thermal Zone> on acpi0
uart0: <16550 or compatible> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0
uart1: <16550 or compatible> port 0x2f8-0x2ff irq 3 on acpi0
ipmi0: <IPMI System Interface> port 0xca2,0xca3 on acpi0
ipmi0: KCS mode found at io 0xca2 on acpi
orm0: <ISA Option ROMs> at iomem 0xc0000-0xc7fff,0xce000-0xcefff on isa0
coretemp0: <CPU On-Die Thermal Sensors> on cpu0
est0: <Enhanced SpeedStep Frequency Control> on cpu0
coretemp1: <CPU On-Die Thermal Sensors> on cpu1
est1: <Enhanced SpeedStep Frequency Control> on cpu1
coretemp2: <CPU On-Die Thermal Sensors> on cpu2
est2: <Enhanced SpeedStep Frequency Control> on cpu2
coretemp3: <CPU On-Die Thermal Sensors> on cpu3
est3: <Enhanced SpeedStep Frequency Control> on cpu3
coretemp4: <CPU On-Die Thermal Sensors> on cpu4
est4: <Enhanced SpeedStep Frequency Control> on cpu4
coretemp5: <CPU On-Die Thermal Sensors> on cpu5
est5: <Enhanced SpeedStep Frequency Control> on cpu5
coretemp6: <CPU On-Die Thermal Sensors> on cpu6
est6: <Enhanced SpeedStep Frequency Control> on cpu6
coretemp7: <CPU On-Die Thermal Sensors> on cpu7
est7: <Enhanced SpeedStep Frequency Control> on cpu7
ZFS filesystem version: 5
ZFS storage pool version: features support (5000)
Timecounters tick every 1.000 msec
freenas_sysctl: adding account.
freenas_sysctl: adding directoryservice.
freenas_sysctl: adding middlewared.
freenas_sysctl: adding network.
freenas_sysctl: adding services.
ipfw2 (+ipv6) initialized, divert enabled, nat enabled, default to accept, logging disabled
ugen0.1: <0x8086 XHCI root HUB> at usbus0
uhub0: <0x8086 XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus0
mps0: SAS Address for SATA device = 4f64524ddcb3d283
ipmi0: IPMI device rev. 1, firmware rev. 1.58, version 2.0
mps0: SAS Address for SATA device = 49656165de8ebc82
ipmi0: Number of channels 2
mps0: SAS Address for SATA device = 4f685257ceb5bd90
ipmi0: Attached watchdog
mps0: SAS Address for SATA device = 49696b59df92e197
mps0: SAS Address for SATA device = d558422890a1be89
mps0: SAS Address for SATA device = 3d63422890a1be8c
mps0: SAS Address for SATA device = 4f665957bbb4d995
mps0: SAS Address for SATA device = 4f626958dcb8d78e
mps0: SAS Address from SATA device = 4f64524ddcb3d283
mps0: SAS Address from SATA device = 49656165de8ebc82
mps0: SAS Address from SATA device = 4f685257ceb5bd90
mps0: SAS Address from SATA device = 49696b59df92e197
mps0: SAS Address from SATA device = d558422890a1be89
mps0: SAS Address from SATA device = 3d63422890a1be8c
mps0: SAS Address from SATA device = 4f665957bbb4d995
mps0: SAS Address from SATA device = 4f626958dcb8d78e
uhub0: 26 ports with 26 removable, self powered
ugen0.2: <vendor 0x0557 product 0x7000> at usbus0
uhub1 on uhub0
uhub1: <vendor 0x0557 product 0x7000, class 9/0, rev 2.00/0.00, addr 1> on usbus0
uhub1: 4 ports with 3 removable, self powered
ugen0.3: <vendor 0x0557 product 0x2419> at usbus0
ukbd0 on uhub1
ukbd0: <vendor 0x0557 product 0x2419, class 0/0, rev 1.10/1.00, addr 2> on usbus0
kbd2 at ukbd0
ada0 at ahcich0 bus 0 scbus1 target 0 lun 0
ada0: <PNY CS900 120GB SSD CS900613> ACS-4 ATA SATA 3.x device
ada0: Serial Number PNY45191911060510727
ada0: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
ada0: Command Queueing enabled
ada0: 114473MB (234441648 512 byte sectors)
ada1 at ahcich1 bus 0 scbus2 target 0 lun 0
ada1: <ADATA SP600 5.8> ACS-2 ATA SATA 3.x device
ada1: Serial Number 2G4220046014
ada1: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
ada1: Command Queueing enabled
ada1: 30533MB (62533296 512 byte sectors)
ada2 at ahcich2 bus 0 scbus3 target 0 lun 0
ada2: <PNY CS900 120GB SSD CS900613> ACS-4 ATA SATA 3.x device
ada2: Serial Number PNY45191911060510723
ada2: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
ada2: Command Queueing enabled
ada2: 114473MB (234441648 512 byte sectors)
ada3 at ahcich3 bus 0 scbus4 target 0 lun 0
ada3: <ADATA SP600 5.8> ACS-2 ATA SATA 3.x device
ada3: Serial Number 2G4220046674
ada3: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
ada3: Command Queueing enabled
ada3: 30533MB (62533296 512 byte sectors)
ada4 at ahcich4 bus 0 scbus5 target 0 lun 0
ada4: <ST4000VN008-2DR166 SC60> ACS-3 ATA SATA 3.x device
ada4: Serial Number ZGY0323V
ada4: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
ada4: Command Queueing enabled
ada4: 3815447MB (7814037168 512 byte sectors)
ada5 at ahcich5 bus 0 scbus6 target 0 lun 0
ada5: <ST4000VN008-2DR166 SC60> ACS-3 ATA SATA 3.x device
ada5: Serial Number WDH15H10
ada5: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
ada5: Command Queueing enabled
ada5: 3815447MB (7814037168 512 byte sectors)
ada6 at ahcich6 bus 0 scbus7 target 0 lun 0
ada6: <ST4000VN008-2DR166 SC60> ACS-3 ATA SATA 3.x device
ada6: Serial Number ZGY030TL
ada6: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
ada6: Command Queueing enabled
ada6: 3815447MB (7814037168 512 byte sectors)
ada7 at ahcich7 bus 0 scbus8 target 0 lun 0
ada7: <ST4000VN008-2DR166 SC60> ACS-3 ATA SATA 3.x device
ada7: Serial Number WDH15GV0
ada7: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
ada7: Command Queueing enabled
ada7: 3815447MB (7814037168 512 byte sectors)
da0 at mps0 bus 0 scbus0 target 0 lun 0
da7 at mps0 bus 0 scbus0 target 7 lun 0
da0: <ATA WDC WD40EFRX-68N 0A82> Fixed Direct Access SPC-4 SCSI device
da0: Serial Number WD-WCC7K2AAVSKC
da0: 3815447MB (7814037168 512 byte sectors)
da0: quirks=0x8<4K>
da2 at mps0 bus 0 scbus0 target 2 lun 0
da2: <ATA WDC WD40EFRX-68N 0A82> Fixed Direct Access SPC-4 SCSI device
da2: Serial Number WD-WCC7K6AKHU6P
da2: 3815447MB (7814037168 512 byte sectors)
da2: quirks=0x8<4K>
da6 at mps0 bus 0 scbus0 target 6 lun 0
da6: <ATA WDC WD40EFRX-68N 0A82> Fixed Direct Access SPC-4 SCSI device
da6: Serial Number WD-WCC7K4HK5TRU
da6: quirks=0x8<4K>
da7: <ATA WDC WD40EFRX-68N 0A82> Fixed Direct Access SPC-4 SCSI device
da7: Serial Number WD-WCC7K0XLVXPN
da7: quirks=0x8<4K>
da1 at mps0 bus 0 scbus0 target 1 lun 0
da1: <ATA WDC WD40EFRX-68W 0A82> Fixed Direct Access SPC-4 SCSI device
da1: Serial Number WD-WCC4E3PP705E
da1: 3815447MB (7814037168 512 byte sectors)
da1: quirks=0x8<4K>
da3 at mps0 bus 0 scbus0 target 3 lun 0
da3: <ATA WDC WD40EFRX-68W 0A82> Fixed Direct Access SPC-4 SCSI device
da3: Serial Number WD-WCC4E7ZD84ZZ
da3: 3815447MB (7814037168 512 byte sectors)
da3: quirks=0x8<4K>
random: unblocking device.
da4 at mps0 bus 0 scbus0 target 4 lun 0
da4: <ATA HITACHI HUS72404 NS04> Fixed Direct Access SPC-4 SCSI device
da4: Serial Number PAJKJG8S
da5 at mps0 bus 0 scbus0 target 5 lun 0
da5: <ATA HITACHI HUS72404 NS04> Fixed Direct Access SPC-4 SCSI device
da5: Serial Number PAJN2R8S
Trying to mount root from zfs:freenas-boot/ROOT/default []...
igb0: link state changed to UP
GEOM_MIRROR: Device mirror/swap0 launched (2/2).
GEOM_MIRROR: Device mirror/swap1 launched (2/2).
GEOM_MIRROR: Device mirror/swap2 launched (2/2).
GEOM_MIRROR: Device mirror/swap3 launched (2/2).
GEOM_MIRROR: Device mirror/swap4 launched (2/2).
GEOM_ELI: Device mirror/swap0.eli created.
GEOM_ELI: Encryption: AES-XTS 128
GEOM_ELI:     Crypto: hardware
GEOM_ELI: Device mirror/swap1.eli created.
GEOM_ELI: Device mirror/swap2.eli created.
GEOM_ELI: Device mirror/swap3.eli created.
GEOM_ELI: Device mirror/swap4.eli created.
hwpmc: SOFT/16/64/0x67<INT,USR,SYS,REA,WRI> TSC/1/64/0x20<REA> IAP/4/48/0x3ff<INT,USR,SYS,EDG,THR,REA,WRI,INV,QUA,PRC> IAF/3/48/0x67<INT,USR,SYS,REA,WRI>
ums0 on uhub1
ums0: <vendor 0x0557 product 0x2419, class 0/0, rev 1.10/1.00, addr 2> on usbus0
ums0: 3 buttons and [Z] coordinates ID=0
bridge0: Ethernet address: 02:f3:1e:59:bf:00
bridge0: link state changed to UP
igb0: promiscuous mode enabled
epair0a: Ethernet address: 02:66:d0:00:05:0a
epair0b: Ethernet address: 02:66:d0:00:06:0b
epair0a: link state changed to UP
epair0b: link state changed to UP
epair0a: changing name to 'vnet0:1'
vnet0:1: promiscuous mode enabled
tap0: Ethernet address: 00:bd:fd:c4:fd:00
tap0: promiscuous mode enabled
tap0: link state changed to UP
tap0: link state changed to DOWN
tap0: Ethernet address: 00:bd:0d:5c:8a:00
tap0: Ethernet address: 00:bd:d2:fc:ff:00
arp: 192.168.4.251 moved from 40:6c:8f:2b:d6:2d to 7c:c3:a1:b1:0d:2e on igb0
arp: 192.168.4.251 moved from 7c:c3:a1:b1:0d:2e to 40:6c:8f:2b:d6:2d on igb0
tap0: Ethernet address: 00:bd:8f:e2:00:00
tap0: Ethernet address: 00:bd:c0:38:15:00
tap0: Ethernet address: 00:bd:c2:17:18:00
tap0: Ethernet address: 00:bd:80:c7:1c:00
tap0: Ethernet address: 00:bd:5d:11:1f:00
tap0: Ethernet address: 00:bd:34:00:a1:00
tap0: Ethernet address: 00:bd:2f:fe:de:00
dmesg.today
ukbd0 on uhub1
kbd2 at ukbd0
da0: quirks=0x8<4K>
da2: quirks=0x8<4K>
da6: quirks=0x8<4K>
da7: quirks=0x8<4K>
da1: quirks=0x8<4K>
da3: quirks=0x8<4K>
ums0 on uhub1
tap0: Ethernet address: 00:bd:5e:c1:90:00
tap1: Ethernet address: 00:bd:e9:45:b7:01
tap1: promiscuous mode enabled
tap1: link state changed to UP
tap1: link state changed to DOWN
tap1: Ethernet address: 00:bd:96:83:bd:01
ps aux
USER    PID %CPU %MEM    VSZ    RSS TT  STAT STARTED     TIME COMMAND
root   4345  0.0  0.0   6544   2344  -  IsJ  17Feb20  0:00.05 dhclient: epair0b [priv] (dhclient)
_dhcp  4444  0.0  0.0   6544   2460  -  ICsJ 17Feb20  0:00.04 dhclient: epair0b (dhclient)
root   4669  0.0  0.0   6420   2484  -  SsJ  17Feb20  0:01.65 /usr/sbin/syslogd -c -ss
plex   4726  0.0  0.3 202512 113060  -  IsJ  17Feb20  8:52.87 /usr/local/share/plexmediaserver-plexpass/Plex_Media_Server (Plex Media Server)
root   4733  0.0  0.0   6460   2344  -  SsJ  17Feb20  0:02.24 /usr/sbin/cron -J 15 -s
plex   4759  0.0  0.2 111128  60836  -  INJ  17Feb20 13:57.81 Plex Plug-in [com.plexapp.system] /usr/local/share/plexmediaserver-plexpass/Resou
plex   4815  0.0  0.1  31716  20380  -  IJ   17Feb20  0:19.76 /usr/local/share/plexmediaserver-plexpass/Plex Tuner Service /usr/local/share/ple
root  66427  0.0  0.0   6948   2852  2  IJ   13:22    0:00.00 login [pam] (login)
root  66428  0.0  0.0   7412   3596  2  SJ   13:22    0:00.01 -csh (csh)
root  67011  0.0  0.0   6920   2636  2  R+J  13:24    0:00.00 ps aux
ls -l
root@plex:~ # ls -l
total 48
-rw-r--r--  2 root  wheel  957 Jul  4  2019 .cshrc
-rw-r--r--  1 root  wheel  149 Jul  4  2019 .k5login
-rw-r--r--  1 root  wheel  395 Jul  4  2019 .login
-rw-r--r--  2 root  wheel  474 Jul  4  2019 .profile
