Hi guys!
I just upgraded from FreeNAS 9.2.1.6 to 9.3 and everything is working fine, except Plex.
I tried upgrading Plex to 0.9.11.4.739_1 (can't remember which version I had before) but it failed. So I decided to remove the plugin completely and install it again. Now the setup assistant for Plex isn't showing up (only the EULA) and if I add my folders manually, none of my media shows up. From the looks of it - it seems that the install isn't complete, like some components are missing, since even Plex Channels isn't listing any channels. I've attached some screenshots so that you can see my entire setup process.
I've also tried completely removing all of my plugins and jails (the whole dataset) and then reinstalling it once again. Same issue. I haven't tinkered with any permissions (since Plex worked before with my current permissions).
The one thing I remember doing after upgrading FreeNAS was updating the ZFS pool since FreeNAS gave me a warning that mine was outdated.
Does anyone have an idea of what the issue might be?
