fizzgig656
- Nov 6, 2012
It seems this has been touched on a little an ive tried to find out ( over the last 2 days on and off) and sort this myself by reading other threads. but i can not quiet get it to work.
so ive had plex running on an old jail (11.1 or before) and is still running but on another ip (192.168.10.51) Ive now upgraded to 11.2 and tried setting up the new plex plugin. Now i can get it to work using DHCP and brings down poster art etc.
But i want it to be on a static ip, so if i "untick" DHCP and select EM1, set ip to 192.168.10.41 using /24 and 192.168.10.1 at default gateway. i can not connect to the plex webpage, unless i "untick" VNET an Berkeley Packet Filter. Then i can connect to plex, setup everything etc, BUT no posters etc.
So i believe this is due to plex not getting details back when searching for info online. The old jail had VIMAGE ticked, so ive tried setting up VNET but im either not setting it up correctly or doing something wrong. so what do i need to do?? currently the fields i "believe" i need to setup or enable are;
DHCP - unticked
VNET - ticked
Berkeley Packet Filter - Ticked
IPv4 interface - EM1
IPv4 address - 192.168.10.41
IPv4 netmask - /24
allow raw sockets - tried it ticked and unticked (previous 11.1 had this set to true!)
VNET interfaces - none , tried vnet0 and em1 TNA (is this correct)?
Interfaces - vnet:bridge0 (is this correct, tried vnet0:em1, TNA)?
vnet default interface - auto (is this correct, tried em1 and vnet0, TNA)??
vnet0 mac - tried none and 00259038246b 00259038246c as it was in a 2nd plex i installed. TNA (is this correct)?
i know im a notice but do try to find the answers without just post here first to save time and people going over it all a number of times. so thanks for looking and helping if you can!
DHCP - unticked
VNET - ticked
IPv4 netmask - /24
