UnderSlepT
- Aug 28, 2018
I am slowly upgrading my current NAS and I am planning to get the most of my future 10gb connection. Currently I have this setup :
CPU - Intel Pentium G4600
RAM - 2 x Crucial 4GB DDR4 2400 MHz
MB - ASUS PRIME B250M-K
Boot - 2x 16GB Sandisk Cruzer
Pool 1 - Raidz1, 3x 3TB WD RED
Pool 2 - Kingston V300 120GB
Now I am planning to currently add additional 3 WD Reds to pool1, rebuild it as mirror and switch the boot volume to Intel Optane 16GB (1 of the flash disks throws errors after just 8 months of use and they generate alot of heat). My goal is 8-12 WD Reds in pool1, and potentially upgrade pool2 to mirror of 1TB SSDs for my VM host. Currently I use intel SATA, I plan to switch to LSI 9300 series 16 port HBA. My network card is currently Intel PRO 1000/CT, will add Intel chipset based Supermicro SFP+ card. For system I will probably use one of the newer Ryzen 5 quad cores with X470 + 32GB ECC RAM.
Currently they have on sale Intel Optane 900p and 800p, so I was wondering if I set the pool to always write in a synchronous way, will it improve CIFS performance when working with small files, since everything will be quickly written to Log disk, and then sequentially written to harddrives? I am asking, since I have only read about L2ARC and LOG propper use / size planning.
