Running pi hole on raspberry pis is overkill
Not for me.
I’ll double check my install.
Forget about Internet guides. Always rely on Pi-Hole
documentation, RasPi Lite 64 + Pihole +
unbound is the way to go. Three commands and you are done, cannot be simpler than that.
# curl -sSL https://install.pi-hole.net | bash
# apt-get -y install unbound
# cat > /etc/unbound/unbound.conf.d/pi-hole.conf << 'EOF'
server:
verbosity: 0
interface: 127.0.0.1
port: 5335
do-ip4: yes
do-udp: yes
do-tcp: yes
do-ip6: no
prefer-ip6: no
harden-glue: yes
harden-dnssec-stripped: yes
use-caps-for-id: no
edns-buffer-size: 1232
prefetch: yes
num-threads: 1
so-rcvbuf: 1m
private-address: 192.168.0.0/16
private-address: 169.254.0.0/16
private-address: 172.16.0.0/12
private-address: 10.0.0.0/8
private-address: fd00::/8
private-address: fe40::/10
private-address: fe80::/10
EOF
I don't trust any DNS services on my home network, having my own recursive DNS is prime. You don't rely on anyone, but you need redundancy.
I'm done hijacking the thread, sorry guys.
