Gh0stShell
- Aug 14, 2023
Hey folks, I want to Passthrough the USB Controller from the Mainboard to my Home Assistant VM. I did all the SSH Stuff with PowerShell with root user.
I am using TrueNAS Core 13.0-U5.1
MB: ASUS Prime B350 Plus
CPU: Ryzen 5 1600
RAM: 32GB
Drives:
Bios changes:
I marked the ones that I added for this project
I checked MSI Support for the Controller:
I cheked IOMMU:
I read, that it don't use DMAR but AMDVi on AMD Systems. And here is my first "problem". When I do an I obviously get nothing.
But when I do an I also don't get any output.
I thought it could be, that I misunderstood something and I only need IOMMU, but I can't pass through the controller. I can still connect a keyboard on it and directly control the TrueNAS and when I want to add a PCI Passthru Device into my VM, I can't see the device.
No PCI Device
What am I missing there. Did I forget something in the BIOS or do I need to add some tunables?
Am I missing something else?
CPU: Ryzen 5 1600
RAM: 32GB
Drives:
- NVMe 256GB for Jails
- SSD 256GB for VMs
- IronWolf Pro 4TB for some Data
Bios changes:
- IOMMU from Auto to Enabled.
- SR-IOV from Disabled to Enabled.
xhci0@pci0:2:0:0: class=0x0c0330 rev=0x02 hdr=0x00 vendor=0x1022 device=0x43bb subvendor=0x1b21 subdevice=0x1142
vendor = 'Advanced Micro Devices, Inc. [AMD]'
device = '300 Series Chipset USB 3.1 xHCI Controller'
class = serial bus
subclass = USB
cap 05[50] = MSI supports 8 messages, 64 bit enabled with 1 message
cap 01[78] = powerspec 3 supports D0 D3 current D0
cap 10[80] = PCI-Express 2 legacy endpoint max data 128(512) RO NS
max read 512
link x4(x4) speed 8.0(8.0) ASPM disabled(L0s/L1)
ecap 0001[100] = AER 1 0 fatal 0 non-fatal 2 corrected
ecap 0019[200] = PCIe Sec 1 lane errors 0
ecap 0018[300] = LTR 1
ecap 001e[400] = L1 PM Substates 1I cheked IOMMU:
# dmesg | grep -i IOMMU amdiommu0 at device 0.2 on pci0 ivhd0: <AMD-Vi/IOMMU ivhd with EFR> on acpi0
acpidump -t | grep DMAR
But when I do an
acpidump -t | grep AMDVi
No PCI Device
