ViciousXUSMC
- May 12, 2014
Dell r710 inbound to do my build with.
Going to go ahead and give the new FreeNAS 11 a shot.
This server comes with the PERC6i and I understand from reading it does not have a JBOD mode.
I also read you "can" potentially just setup each disk as a virtual disk with raid 0 and that "should" work.
However... "can" and "should" are not very good for making decisions.
Is this as good as real JBOD or could this cause unforeseen issues?
Edit: I may also be in trouble as I think I just found the PERC6i not to support disks as large as mine (8TB WD RED)... so that is not an option anyways.
I hope to find 6x SATA ports on the Mobo if not I'll look up buying one of the recommended HBA's
So that sort of changes the question to... What HBA is a good fit for the r710 that will work with its existing backplane and plug right in to support 6x8TB drives.
