Partial plugin destroyed
hziro
Dear All,
thanks in advance whom can help me.
This morning i played (my mistake) in the shell with permissions, i changed the permissions of my "MNT", and after that my plugins stopped to run and if i try to install new one the system show me this error "test had a failure Exception: RuntimeError Message: pkg error: - pkg-static: . permissions (0774) too lax Please check your network Partial plugin destroyed".
There is any chance to restore the package or something in order to avoid the hard restore?
Samuel Tai
ls -ld /mnt will show the permissions of the /mnt directory. On my system, they look like:
drwxr-xr-x  3 root  wheel  128 Sep 30 08:46 /mnt/
hziro
The permissions are ok.
The problem is the pkg destroyed, due to that i can't install or use plugins.
Samuel Tai
The error message is complaining about the permissions of pkg-static as 0774. This should be 0755:
root@raven:~ # ls -l /usr/local/sbin/pkg-static
-rwxr-xr-x  1 root  wheel  6490488 Sep 30 08:41 /usr/local/sbin/pkg-static*
Samuel Tai
chmod 0755 /usr/local/sbin/pkg-static
Samuel Tai
What does ls -l /usr/local/sbin/pkg-static show?
