James1432
- Mar 28, 2016
Build FreeNAS-9.3-STABLE-201601181840
Platform AMD Athlon(tm) II X3 440 Processor
Memory 32715MB
Hi there
After 6 months of pulling out my hair I have managed to get this to work! If somebody could give me a real noob way of doing the following.. I'd be really impressed!
1. Install my Godaddy SSL 'EASILY'
2. Get owncloud to display my server name when forwarded from godaddy
3. EASILY customise the CSS of the plugin.. Surprised there isn't a plugin for this (Tried theme switcher but didn't work)
Not amazingly confident at this and was hoping there would be an easy way?
or if I could just..
Filezilla into Freenas and nav down to the owncloud/apache24/www/whatever and just drag and drop my godaddy ssl bundle and cert in this way? Some advice here would be great please? Assuming that owncloud still needs to create a key and .pem files??
For those struggling with the whole trusted domain thing.. its actually very simple, This will get you to where I am, if the other methods dont work.. Had major Grief with this and this is by no means supposed to be educational.
1. Purchase a static IP pack from your provider
2. Install owncloud plugin (!!!DO NOT ACTIVATE!!!)
3. Create Storage
4. Ensure storage and jail permissions are set to www
5. Go to your router and assign a static IP to the IP address of the owncloud jail.. (+port forwarding)
6. Restart owncloud jail
7. Activate owncloud plugin
8. Your static IP is now a trusted Domain
9. Still have to follow guides to add your FQDN in the right place but relatively easy at this point.
For those in the UK.. !!GET A DECENT ROUTER!! and ISP
Memory 32715MB
Hi there
3. Create Storage
