OwnCloud Jails plugin Add Storage [SOLVED]
siteswap
Good evening everyone
I have 2 hhd in mirror (DataBackup) and a hdd for the jails plugin (PluginHdd)
I have a little problem to add my files to owncloud , I created a dataset called Music (under DataBackup) and a shared folder, and added that dataset to jail , but unfortunately I can not see any files
Also using the app support external storage can not map the folder
please give me a hand
Thank you ...... and sorry for my bad English
Joshua Parker Ruehlig
can you show...
* your 'External Storage Support' settings
* the output of 'ls -l /mnt/Musica'
siteswap
Hi joshua , first of all thank you for answering
These are the ip information :
Freenas is https://192.168.1.3 ,and Owncloud is https://192.168.1.5
Cifs folder is : /mnt/DataBackup/Musica
Firts image is"External Storage Support"
Second image is output of /mnt/Musica
Just for info , Ive also imported SSL certificate in OwnCloud
pirateghost
Unintelligible Geek
Shouldn't you be using the "local storage" option in external storage plugin?
pirateghost
Unintelligible Geek
I don't use own cloud but have seen mention of this plugin before.
From your screenshots, you're adding storage to the jail, but then in own cloud you're attempting to mount an smb/cifs share. You don't need both of these things.
I think there is an option in the external storage plugin that allows you to point to a directory. Point it to /mnt/Musica
siteswap
Yeah Man it works !!!!! EUREKA
if I were a woman I would kiss you
Thank you so much
lol, nice.
