bigzaj
- Jan 6, 2016
So I spent quite a bit of time on Corral and figuring out dockers, etc. Unfortunately the system is just to unstable and I figure now is as good a time as any to move on to FN11 and the first app I am tackling in Plex. I am getting confused with how to configure data locations etc.
Jails root folder -> (mnt/jails)
I started by creating a Jails volume -> apps dataset -> plex dataset (mnt/jails/apps/plexjail)
Then I created a Jail called plex which of course created a dataset? called plex in the the Jails root (mnt/jails/plex)
As I did with Dockers in Corral, my plan was to have a dataset per app to store the application data. Do I need to add storage to the jail pointed to (mnt/jails/apps/plexjail)? If so what would the associated Plex folder be for all of the data settings, etc.
Thank you.
Thank you.
