"Orphaned" transmission plugin installation
I'm running FreeNAS 9.2.1.5, having incrementally upgraded from 8.something over the last couple of years. At some point in the past, I attempted to install a plugin for transmission 2.77. It didn't work at the time, and I didn't mess with it much. However, I now can't remove it. It's listed under my installed plugins next to an installation of transmission 2.82 (which has its own problems, but that's a separate issue). Next to the 2.77 listing, there's a button for Update and another for Delete. When I try to delete it, I get an error that "the plugins jail is not running, start it before proceeding."
The Transmission 2.77 does not appear to have an associated jail. How can I clear out this entry?
D
dlavigne
Guest
I asked the developer who said:
It might be best to just nuke the jail dataset in this case. This was fixed, but I think it's in 9.2.1.6. The meta data directory will need to
be removed as well:
zfs destroy -f /mnt/$vol/jails/transmission_xxx
rm -rf /mnt/$vol/jails/.transmission_xxx.meta
Replace _xxx with the name of the problematic jail.
Thanks for the reply. It doesn't appear that there is a jail, dataset, or a meta data directory for this transmission installation. Both are present for the (semi-working) 2.82 installation, though.
[dan@freenas2] /mnt/zfs1/jail# ls -l
total 19
drwxr-xr-x  9 root  wheel  10 May  5 18:11 ./
drwxrwxrwx  13 root  wheel  13 May 20 16:53 ../
drwxr-xr-x  3 www  www      3 May  5 18:01 .plugins/
drwxr-xr-x  2 root  wheel  17 May  5 18:11 .transmission_1.meta/
drwxr-xr-x  4 root  wheel    4 Aug 24  2013 .warden-files-cache/
drwxr-xr-x  17 root  wheel  21 Dec  4  2012 .warden-template-9.1-RELEASE-amd64/
drwxr-xr-x  18 root  wheel  22 May  5 18:04 .warden-template-pluginjail/
drwxr-xr-x  19 root  wheel  24 May 26  2013 transmission/
drwxr-xr-x  18 root  wheel  22 May  5 18:04 transmission_1/
-rw-r--r--  1 root  wheel  170 May  5 18:11 warden.log
transmission_1 is the one that works, transmission doesn't. transmission_1 is a dataset, transmission isn't. I can certainly rm -rf transmission--is that the best bet?
D
dlavigne
Guest
Sounds reasonable. Let us know if that fixes it or fails.
The rm succeeded--the directory /mnt/zfs1/jail/transmission has been removed. However, the plugin is still listed as installed (see attached).
D
dlavigne
Guest
Was there an associated /mnt/$vol/jails/.transmission_xxx.meta and was that file removed?
D
dlavigne
Guest
Not sure... If on the chance you have resolved this, post how you did it.
No resolution. It appears to be only a cosmetic issue, so I'm not too bothered by it, but it seems there ought to be a way to clean up that list when it gets out of sync with reality.
Big Al
I had the same issue with "transmission" as well as a couple other plugins on an unsuccessful attempt to install on an older version (~2years ago). I've attempted to move the software remnants off into another subdirectory but didn't seem to have any effect. I suspect that there are some orphaned stubs sitting in some sqlite database since the configuration backup process produces an sqlite database. I'm not proficient at ransacking databases so I didn't try to putz with probing databases.
Since there is ZFS on the volumes and my FreeNAS installation is on a separate and dedicated SSD, I did a fresh installation in order to clear up this and any other hidden woes. With the clean install, my jail root was on the ZFS volume. I had to clean up the previously valid jails to valid plugins on the prior installation (nothing lost there) and configured the jail root to that volume again. I went ahead and left the warden dataset alone.
After rebooting, the plugin list refreshed. I was able to start with a clean list of plugins associated with (fresh) valid jails. Had I not had the firmware/OS installed on its own disk, I would not have been able to do this cowardly fix.
Sirach Matthews
I am a Noob, so forgive me if I am completely off base here.
Is there some entry in /data/freenas-v1.db which needs cleaning up? I have a similar issue here.
volckg
Hi everybody, I also am a FreeNAS Noob, but maybe found a workaround for orphaned plugins (at least for my setup).
I had 2 plugins installed "owncloud" and "crashplan" when I lost the pool. Didn't hurt because it was only for testing purposes. I setup a new pool and noticed, the plugins showed up in the list of the web interface but couldn't be removed.
I then tried to reinstall "owncloud" from the available plugins list, but installation stopped with the error message: "jexec: execvp(): /usr/pbi/owncloud-amd64/control: No such file or directory". After that I was able to delete the plugin through the web interface. Same thing for the "crashplan" plugin. After a reboot I reinstalled the "owncloud" plugin and it works as expected.
Cheers,
Gerrit
