UncrushedTolerant
- Aug 17, 2022
Hello everyone,
I'm am brand new to truenas and am looking for a little bit of help.
I had a windows pc acting as a file server and was also running oracle VM for a few Linux servers that I needed.
After much searching, I found out that I needed to convert the oracle vm disk from .vdi to a raw .img... I got that all done and have the raw file in a dataset called "Servers".
My commands...
Windows PC: VBoxManage clonehd --format raw C:\Users\User$\Desktop\Website\Website.vdi C:\Users\User$\Desktop\Website\Website.raw
Truenas SSH: dd if=/mnt/Pool/Servers/Website/Website.raw of=/dev/zvol/Pool/Servers/Website-zvol status=progress
I got the vdi files converted to a raw file...
https://pasteboard.co/SBUXbGuyteIf.png
Got the vm setup in truenas click on Start and then VNC and all it would show is this...
https://pasteboard.co/Uk2xH2T3dbPQ.png
And now nothing... still no vm started, still no website that i need running. :(
I tried changing the disk mode from AHCI to VirtIO
This is getting me no where and the reason I decided to use truenas was it had the VM feature and it was open source.
If I can't get to work, then I will have to look at another option, which I have already wasted 5 days moving all of my data back and forth, as well as, my club's website down for the same time.
I'm at a loss, I'm not sure what to do to get this working. I want to believe that truenas can get this working, but I have no clue if I am doing something wrong or if truenas is like nope.
My commands...
