Only 155MB/s On 2.5Gb LAN with 10Gb NIC
XenoMorpHx
I am using Truenas for quite some years now and all worked just fine on a 1Gb LAN setup, max speed of 110-115MB/s.
Recently I upgraded my Internet connection to 2Gb, so to also upgrade my LAN I replaced some of my 1Gb hardware with 2.5Gb and 10Gb capable switches ad replaced cabels with CAT6 ones.
I bought an X550-T1 10Gb (Genuine one) NIC for the NAS and for my pc I would still use the 2.5NIC on the mainboard.
NAS setup (I know, it's a few years old, but still doing it's job):
Asrock AM1H-ITX
AMD Athlon 5350
8GB DDR3 RAM
Bootdisc: Kingston 60GB SSD
Pool1: 2x 4TB WD Red: WD-WCC7K5SJA717 / WD-WX52D21CSZCV (mirror)
Pool 2: 1x 4TB WD Red: WD-WCC7K3KZ84YN
Pool 3: 1x USB 3.1 (up to 5Gb/s), a 4TB Crucial P3 NVMe SSD in an USB enclosure.
The X550-T1 is in a 1 x PCI Express 2.0 x16 Slot (PCIE1 @ x4 mode). Max speed at 2 GB/s.
When I transfer a file to either of the drives (even the USB-SSD) the max speed is 150-156MB/s on a 2.5Gb connection. On a 1Gb connection I get about 110MB/s. So there is some gain you'd say.
On iPerf I get:
Server = Truenas
Client = PC
Client connecting to 192.168.10.12, TCP port 5201
Sending 131072 byte packets
TCP window size: 64.0 KByte (default)
[5480] local 192.168.10.67 port 57196 connected with 192.168.10.12 port 5201
[ID]    Interval    Transfer    Bandwidth
[5480] 0.0-2.0 sec   309 MBytes  1.30 Gbits/sec
[5480] 2.0-4.0 sec   310 MBytes  1.30 Gbits/sec
[5480] 4.0-6.0 sec   306 MBytes  1.28 Gbits/sec
[5480] 6.0-8.0 sec   307 MBytes  1.29 Gbits/sec
[5480] 8.0-10.0 sec   304 MBytes  1.27 Gbits/sec
[5480] 0.0-10.9 sec  1.64 GBytes  1.29 Gbits/sec
Server = PC
Client = Truenas
Server listening on TCP port 5201
Receiving 131072 byte packets
[5712] local ::ffff:192.168.10.67 port 5201 connected with ::ffff:192.168.10.12 port 28943
[5712] 0.0-2.0 sec   255 MBytes  1.07 Gbits/sec
[5712] 2.0-4.0 sec   254 MBytes  1.07 Gbits/sec
[5712] 4.0-6.0 sec   254 MBytes  1.07 Gbits/sec
[5712] 6.0-8.0 sec   251 MBytes  1.05 Gbits/sec
[5712] 8.0-10.0 sec   252 MBytes  1.06 Gbits/sec
[5712] 10.0-12.0 sec   250 MBytes  1.05 Gbits/sec
Searching the forum I've read that disabling encryption would help, so I tried that on the USB SSD, with no result, still 150MB/s.
I have no idea why the transfers are so low, I hope anyone could point me in the right direction.
Tony-1971
When iperf is running, your CPU's are running at 100%? The bandwith seems very low.
Best Regards,
Antonio
XenoMorpHx
Hi, I just checked. Core #0 is maxing out @ 100%, the other 3 cores are @ 25-30%.
Tony-1971
If you run iperf with multiple streams you probably see the full bandwith.
But for one transfer you have reached the CPU limit: can you check the CPU usage when performing transfer?
You can try with higher MTU on both ethernet side (and switch).
Etorix
Your results are probably as good as your old NAS with only 8 GB RAM can achieve.
On the read side, 300 MB/s is in the right ballpark for a mirror of two old HDDs (ca. 150 MB/s).
On the write side, you're throttled by RAM, acting as write cache up to two transaction groups. The SSD is crippled by the USB link anyway.
More than RAM, the processor itself is rather puny.
XenoMorpHx
I have set the MTU in Treunas to 9000 (it says 10Gase-T) and in windows to 9000. But no change.
When doing a transfer of a 8GB file, 1 core gets to 100% and the other 3 to 40-50ish.
What Etorix says about the RAM, I checked it during a file transfer and the Free RAM gets used by the ZFS cache, leaving 0.2GiB. Maybe it is the RAM bottle-necking the throughput?
As for the USB disc, I know it's slower cuz of the USB port, but still, it's rated 3.1 5Gb/s and should do 200-250MB/s. I am using it to test the connection speed HDD vs the SSD/USB.
I also changed the cable (what supposed to be a CAT6) with a different 5e cable, and I gained almost 8-10MB/s. But still not the 250-300MB on the USBdrive.
XenoMorpHx
Ok, this is weird...
After switching some cables, I ended up rebooting the server.
After rebooting it and plugging back in the original cable, I did another iperf test.
[5916] local 192.168.10.67 port 61207 connected with 192.168.10.12 port 5201
[5916] 0.0-2.0 sec   590 MBytes  2.47 Gbits/sec
[5916] 2.0-4.0 sec   588 MBytes  2.46 Gbits/sec
[5916] 4.0-6.0 sec   591 MBytes  2.48 Gbits/sec
[5916] 6.0-8.0 sec   591 MBytes  2.48 Gbits/sec
[5916] 8.0-10.0 sec   591 MBytes  2.48 Gbits/sec
[5916] 10.0-12.0 sec   584 MBytes  2.45 Gbits/sec
[5916] 12.0-14.0 sec   591 MBytes  2.48 Gbits/sec
[5916] 14.0-16.0 sec   591 MBytes  2.48 Gbits/sec
[5916] 16.0-18.0 sec   587 MBytes  2.46 Gbits/sec
[5916] 18.0-20.0 sec   591 MBytes  2.48 Gbits/sec
[5916] 20.0-22.0 sec   591 MBytes  2.48 Gbits/sec
[5916] 22.0-24.0 sec   591 MBytes  2.48 Gbits/sec
[5916] 24.0-26.0 sec   591 MBytes  2.48 Gbits/sec
[5916] 26.0-28.0 sec   591 MBytes  2.48 Gbits/sec
[5916] 28.0-30.0 sec   591 MBytes  2.48 Gbits/sec
[5916] 30.0-32.0 sec   591 MBytes  2.48 Gbits/sec
[5916] 32.0-34.0 sec   588 MBytes  2.47 Gbits/sec
[5916] 34.0-36.0 sec   591 MBytes  2.48 Gbits/sec
[5916] 36.0-38.0 sec   591 MBytes  2.48 Gbits/sec
[5916] 38.0-40.0 sec   589 MBytes  2.47 Gbits/sec
[5916] 40.0-42.0 sec   590 MBytes  2.48 Gbits/sec
[5916] 42.0-44.0 sec   591 MBytes  2.48 Gbits/sec
[5916] 44.0-46.0 sec   590 MBytes  2.48 Gbits/sec
[5916] 46.0-48.0 sec   591 MBytes  2.48 Gbits/sec
[5916] 48.0-50.0 sec   591 MBytes  2.48 Gbits/sec
[5916] 50.0-52.0 sec   591 MBytes  2.48 Gbits/sec
[5916] 52.0-54.0 sec   591 MBytes  2.48 Gbits/sec
[5916] 54.0-56.0 sec   591 MBytes  2.48 Gbits/sec
[5916] 56.0-58.0 sec   591 MBytes  2.48 Gbits/sec
[5916] 58.0-60.0 sec   591 MBytes  2.48 Gbits/sec
[5916] 0.0-60.7 sec  17.5 GBytes  2.48 Gbits/sec
A solid 2.5Gb connection. Doing 280MB/s on the SSD/USB (after the RAM is full it drops back to 170MB/s). And
I think the MTU setting needed a server reboot? That did the trick I think.
Thanks for the input all!
BTW, there is a NAS serverboard with an N100 on its way, already bought a 32GB DDR5 SODIMM, so I think that will do the trick much better.
Etorix
Please report on performance with the new server.
XenoMorpHx
No, that's not it. I thought that at first, but the theoretical bandwidth is 2000MB/s.
10Gb speed is approx. 1250MB/s.
To bad I don't have a second 10Gb NIC(these thing cost an arm and a leg) to test that out.
Etorix
Solarflare SFx122F or Chelsio T520 NICs can be found on eBay for $50 or less. Keep your limbs!
