One or more devices has experienced an error resulting in data corruption
Donny Davis
I don't think so. I only use the API for Openstack.
I am still backing up my data. It hasn't thrown any more errors which is good. I am going to run some integrity checks on the data and hopefully all is good. I should have more toward the end of the week.
Donny Davis
Ok so after many days of backing up my data and making sure I am good to start tinkering I am finally there.
Here is the output for all of my drives, but I am not sure what I should be looking for. Never had to get this deep into a drive before, I usually just trash the funky drive and move on... In this case, I don't know which on it is so any help would be appreciated
  • smart-output.txt
Yorick
Donny Davis
So I ran the long tests and they showed the same result. *attached*
So I am unsure of how to proceed from here.
Should I clear the error and keep a close watch on it? Maybe bump up the backup schedule
  • self-test-report.txt
pro lamer
Have you ruled out overheating issues? If the drives had not overheated (which I don't know ATM since I haven't read your attachments) it might have been sth else for example the HBA or in theory even the RAM (this is just a guess I'm not experienced in RAM but usually ECC can detect up to a double bit error and hypothetical multi bit error might have passed).
I also had an issue once that an SSD silently corrupted some data and I suspected temporary overheating incident...
And the metadata corruption seems scary - I've seen a case in our forums that pool metadata corruption kept causing more and more errors and they nuked the pool eventually...
BTW have you updated the firmware as @Chris Moore suggested?
Sent from my phone
