pious_greek
- Nov 28, 2017
I'm about 32 hours into burn in testing, and Drives 4, 5 and 6 (sata3 - sata5) on the right are running (read/writing) about 15 percent slower than drives 1, 2 and 3 (sata0 - sata2) on the left. I'm running badblocks on all the drives concurrently with TMUX, and the processes were all started in sequntial orders within a few minutes of each other.
Is this a function of the hardware config or is this an installation problem on my end? The hardware config doesn't seem to be taxed, plenty of idle and free ram.
The bend in the SATA is a little tight, but I wouldn't say forced or excessive. The only other consideration i suppose would be additional vibes from the PSU...
last pid: 43279; load averages: 0.57, 0.52, 0.46 up 2+05:29:31 15:26:29 60 processes: 1 running, 59 sleeping CPU 0: 8.9% user, 0.0% nice, 2.0% system, 0.0% interrupt, 89.1% idle CPU 1: 0.0% user, 0.0% nice, 0.0% system, 1.0% interrupt, 99.0% idle CPU 2: 0.0% user, 0.0% nice, 4.0% system, 0.0% interrupt, 96.0% idle CPU 3: 19.8% user, 0.0% nice, 0.0% system, 0.0% interrupt, 80.2% idle CPU 4: 2.0% user, 0.0% nice, 3.0% system, 4.0% interrupt, 91.1% idle CPU 5: 1.0% user, 0.0% nice, 0.0% system, 0.0% interrupt, 99.0% idle CPU 6: 1.0% user, 0.0% nice, 2.0% system, 0.0% interrupt, 97.0% idle CPU 7: 0.0% user, 0.0% nice, 2.0% system, 0.0% interrupt, 98.0% idle Mem: 76M Active, 607M Inact, 876M Wired, 29G Free ARC: 226M Total, 19M MFU, 196M MRU, 16K Anon, 1801K Header, 9382K Other Swap: PID USERNAME THR PRI NICE SIZE RES STATE C TIME WCPU COMMAND 9107 root 2 22 0 127M 32520K select 3 3:44 24.88% python3.6 3933 root 15 20 0 505M 158M umtxn 0 2:18 5.20% uwsgi 65586 root 1 20 0 10620K 2840K physwr 4 73:54 2.38% badblocks 65612 root 1 20 0 10620K 2836K physwr 2 73:02 2.14% badblocks 65420 root 1 21 0 10620K 2836K physwr 5 79:38 2.11% badblocks 65496 root 1 20 0 10620K 2840K physwr 2 72:36 2.00% badblocks 65470 root 1 21 0 10620K 2836K physwr 0 79:16 2.00% badblocks 65462 root 1 21 0 10620K 2836K physwr 7 78:46 1.98% badblocks 3121 root 12 20 0 241M 46968K nanslp 4 5:51 1.90% collectd 43273 root 1 20 0 24272K 3548K CPU4 4 0:00 0.20% top 3071 root 17 46 0 66976K 20128K uwait 6 4:57 0.17% consul 4135 www 1 20 0 30980K 6280K kqread 5 0:00 0.15% nginx 65347 root 1 20 0 22120K 3748K select 3 1:13 0.06% tmux 2174 root 2 20 0 24704K 12544K select 6 0:10 0.01% ntpd 3039 root 1 20 0 407M 99140K kqread 4 0:11 0.00% uwsgi 3042 root 1 52 0 293M 63792K select 6 1:28 0.00% python3.6 1884 root 1 -52 r0 7600K 3572K nanslp 4 0:30 0.00% watchdogd 3075 root 19 20 0 52592K 12004K kqread 7 0:15 0.00% consul-alerts 214 root 6 20 0 406M 98580K kqread 4 0:10 0.00% python3.6 3962 root 1 49 0 236M 57264K wait 0 0:02 0.00% python3.6 4001 root 15 20 0 52320K 14932K uwait 2 0:01 0.00% consul 1756 root 1 20 0 61876K 6720K kqread 4 0:01 0.00% syslog-ng
Parts List: Case: Fractal Design Node 804 PSU: BFG 550 (using it for testing only, will upgrade to more efficient) Motherboard: Supermicro X10SDV-4C+-TLN4F-O (Intel® Xeon® processor D-1518, Single socket FCBGA 1667; 4-Core, 8 Threads, 35W) Memory: 2x 16GB Crucial RDIMM DDR4-2133 MT/S (PC4-2133) CL15 dual ranked x4based ECC Registered Server Memory CT2K16G4RFD4213 USBs: 2x Sandisk Cruzer Fit 16GB USB2 HDs: 6x Seagate IronWolf 8TB
