odoo | Permission denied to create database ??
MagnumPL
Freshly installed app
I can't generate the Database, and when I want to log in to the container, I can't use the nano & vi command
2023-04-23 20:48:42.193829+00:00ERROR: couldn't write the config file
2023-04-23 20:48:42.209985+00:002023-04-23 20:48:42,209 1 INFO None odoo.service.db: Create database `odoo`.
2023-04-23 20:48:42.215706+00:002023-04-23 20:48:42,215 1 ERROR None odoo.sql_db: bad query: CREATE DATABASE "odoo" ENCODING 'unicode' LC_COLLATE 'C' TEMPLATE "template0"
2023-04-23 20:48:42.215749+00:00ERROR: permission denied to create database
2023-04-23 20:48:42.215759+00:002023-04-23T20:48:42.215759227Z
2023-04-23 20:48:42.216331+00:002023-04-23 20:48:42,215 1 ERROR None odoo.http: permission denied to create database
2023-04-23 20:48:42.216346+00:002023-04-23T20:48:42.216346295Z
2023-04-23 20:48:42.216354+00:00Traceback (most recent call last):
2023-04-23 20:48:42.216371+00:00File "/usr/lib/python3/dist-packages/odoo/http.py", line 141, in dispatch_rpc
2023-04-23 20:48:42.216379+00:00result = dispatch(method, params)
2023-04-23 20:48:42.216389+00:00File "/usr/lib/python3/dist-packages/odoo/service/db.py", line 462, in dispatch
2023-04-23 20:48:42.216404+00:00return g[exp_method_name](*params)
2023-04-23 20:48:42.216412+00:00File "<decorator-gen-14>", line 2, in exp_create_database
2023-04-23 20:48:42.216420+00:00File "/usr/lib/python3/dist-packages/odoo/service/db.py", line 41, in if_db_mgt_enabled
2023-04-23 20:48:42.216428+00:00return method(self, *args, **kwargs)
2023-04-23 20:48:42.216442+00:00File "/usr/lib/python3/dist-packages/odoo/service/db.py", line 130, in exp_create_database
2023-04-23 20:48:42.216450+00:00_create_empty_database(db_name)
2023-04-23 20:48:42.216458+00:00File "/usr/lib/python3/dist-packages/odoo/service/db.py", line 112, in _create_empty_database
2023-04-23 20:48:42.216468+00:00cr.execute(
2023-04-23 20:48:42.216483+00:00File "<decorator-gen-3>", line 2, in execute
2023-04-23 20:48:42.216491+00:00File "/usr/lib/python3/dist-packages/odoo/sql_db.py", line 90, in check
2023-04-23 20:48:42.216499+00:00return f(self, *args, **kwargs)
2023-04-23 20:48:42.216507+00:00File "/usr/lib/python3/dist-packages/odoo/sql_db.py", line 313, in execute
2023-04-23 20:48:42.216519+00:00res = self._obj.execute(query, params)
2023-04-23 20:48:42.216527+00:00psycopg2.errors.InsufficientPrivilege: permission denied to create database
2023-04-23 20:48:42.216535+00:002023-04-23T20:48:42.216535362Z
NugentS
Don't you think a little more information might help?
I can tell you - it looks like a permissions issue
MagnumPL
I will gladly provide all logs. only you can write what would be most helpful
aikidd
How do you grant permission to the webUI to create the database after installation?
Failed to work for me today after a fresh install.
"Database creation error: permission denied to create database"
odoo 15.0_13.0.0Up to date
Used Ports:8069\TCP, 8072\TCP, 8071\TCP
Status:ACTIVE
Pods:5
Deployments:2
Statefulsets: 0
Catalog: Truecharts
Train: Stable
Item Name:odoo
sfatula
Since it's Truecharts, I would suggest asking on their support channel, on discord.
