profwalken
- Nov 19, 2013
Hi Have pushed update on 3 FN 11.3-U4.1
on the third one ,I got problem during update, like GUI stay stuck at 62.5%
finally update finished and FN rebooted to latest 11.3-U5
on boot ,in console I get this :
Oct 5 22:29:48 SRV-XXXX ntpd[1388]: restrict: ignoring line 10, address/host '0.freebsd.pool.ntp.org' unusable.
Oct 5 22:29:48 SRV-XXXX ntpd[1388]: restrict: ignoring line 11, address/host '1.freebsd.pool.ntp.org' unusable.
Oct 5 22:29:48 SRV-XXXX ntpd[1388]: restrict: ignoring line 12, address/host '2.freebsd.pool.ntp.org' unusable.
NTP domains are resolved with any problems from server console.
Ntp servers values are default ones in config settings, from GUI i got those lines: They are the same on 3 FN servers i got
but always this in console
I changed NTP servers to french ones with no more result.
Tonight for test I rebooted FN server, and problem is always here
my ntp.conf is like that on server with console message, 2 other FN servers have default file settings and no restrict messages for NTP
Do i need to remove "restrict default ignore" line in that file?
Do you think i need to open a bug ticket?
Where can I do something ?, I have just seen in general system ntp and there are same lines as others FN servers on which these messages doesn't appear.
