system time is off by almost ten minutes but my NTP says it's fine
Jon Krueger
System time is almost ten minutes behind, yet ntp is running. Any ideas?
logs
Oct 9 07:29:22 truenas TSC: P-state invariant, performance statistics
Oct 9 07:29:23 truenas 1 2022-10-09T07:29:23.567111-07:00 truenas.local ntpd 10
53 - - ntpd 4.2.8p15-a (1): Starting
ps -aux | grep ntp
ntpd 1054 0.0 0.0 18564 6680 - Ss 9Oct22 2:50.37 /usr/sbin/ntpd -p /var/db/ntp/ntpd.pid -c /etc/ntp.conf -f /var/db/ntp/ntpd.drif
My NTP conf:
server 0.freebsd.pool.ntp.org iburst maxpoll 10 minpoll 6
server 1.freebsd.pool.ntp.org iburst maxpoll 10 minpoll 6
server 2.freebsd.pool.ntp.org iburst maxpoll 10 minpoll 6
restrict default ignore
restrict -6 default ignore
restrict 127.0.0.1
restrict -6 ::1
restrict 127.127.1.0
restrict 0.freebsd.pool.ntp.org nomodify notrap nopeer noquery
restrict 1.freebsd.pool.ntp.org nomodify notrap nopeer noquery
restrict 2.freebsd.pool.ntp.org nomodify notrap nopeer noquery
ntpq -pw
remote refid st t when poll reach delay offset jitter
192.168.1.1 .INIT. 16 u - 1024 0 0.000 +0.000 0.000
ping 0.freebsd.pool.ntp.org
PING 0.freebsd.pool.ntp.org (44.4.53.4): 56 data bytes
64 bytes from 44.4.53.4: icmp_seq=0 ttl=48 time=25.852 ms
64 bytes from 44.4.53.4: icmp_seq=1 ttl=48 time=28.082 ms
Thanks!
-- Jon
After having issues with time accuracy and reliability with the default entries, early into using FreeNAS/TrueNAS, I only use one entry in my NTP configuration. (I deleted all the default preset entries for *.freebsd.pool.ntp.org)
I haven't had issues since.
Address           Burst    IBurst   Prefer    Min. Poll    Max. Poll
us.pool.ntp.org   no       yes      yes       6            10
WN1X
Your ntpq -pw shows your system is not synced with any NTP server. (Stratum 16 indicates no sync.)
What does ntpq show:
root@truenas[~]# ntpq
ntpq> pe
 time.cloudflare .INIT.          16 u    - 1024    0    0.000   +0.000   0.000
*cambria.bitsrc. 132.163.96.1     2 u  718 1024  377   76.869  +12.266   3.028
+12.167.151.1    158.51.134.123   3 u  790 1024  377   16.132  -11.289   2.008
+tick.srs1.ntfo. 206.55.64.77     3 u  319 1024  377   77.262  +22.597   7.904
ntpq>
Above you can see my TrueNAS is not getting any response from "Time.cloudflare.com", but is synced to 12.167.151.1. When I ran service ntpd restart (I am running Core), new servers were picked up:
ntpq> pe
 66.85.78.80     172.16.23.153    2 u    7   64    1   48.016   -9.198   0.497
 107-137-68-135. 192.168.1.32     2 u    1   64    1   78.062   -0.983   0.601
 time.nullrouten 132.163.97.1     2 u    1   64    1   72.882   +1.108   0.131
*108.61.73.244   128.59.0.245     2 u    1   64    1   10.215   -0.547   0.103
1. I configure my pfSense FW to serve NTP time for all clients and add a FW rule to redirect all outbound port 123 traffic to my local NTP server.
2. You might want to consider checking the CMOS battery. New batteries are ~3.3v and fall off a cliff when low. Anything less than ~3.0v you might want to consider replacing.
[2.6.0-RELEASE][admin@pfSense.redacted.com]/root: ntpq -pn
 us.pool.ntp.org .POOL.          16 p    -   64    0    0.000   +0.000   0.000
-144.172.118.20  154.128.90.233   2 u   68  512  377   36.444   -0.630   0.849
+134.215.114.62  216.239.35.0     2 u  268  512  377   45.366   -0.900   1.238
+23.157.160.168  129.6.15.28      2 u  460  512  377   40.462   +0.198   0.264
*50.205.57.38    .GPS.            1 u   92  512  377   44.116   +0.274   0.126
root@NAS-1[~]# ntpq -pn
*192.168.69.5    50.205.57.38     2 u   27  128  377    0.220   +0.647   0.105
Jon Krueger
ntpq> pe 192.168.1.1 .INIT. 16 u - 1024 0 0.000 +0.000 0.000 (service ntpd restart) ntpq> pe *clock.fmt.he.ne .PPS. 1 u 18 64 1 14.232 -6.554 1.816 backoffice-1.in .STEP. 16 u 746 64 0 0.000 +0.000 0.000 +clock.nyc.he.ne 66.220.9.122 2 u 21 64 1 76.081 -9.933 3.772
And now the time is accurate. Hrm. Fixed?
Reach needs to be 377. Takes a few minutes. If it never equals 377, then you still have a problem.
WN1X
Probably fixed...your first NTP peer report shows TrueNAS was trying to use your router (192.168.1.1) as a time source, but it was not responding; because it isn't running an NTP server. After the restart, things look much better.
Jon Krueger
now:
remote refid st t when poll reach delay offset jitter ============================================================================== *clock.fmt.he.ne .PPS. 1 u 3 64 341 12.902 +106.89 6.707 +backoffice-1.in 206.108.0.133 2 u 58 64 377 67.835 +117.13 2.323 +clock.nyc.he.ne 66.220.9.122 2 u 44 64 377 73.819 +104.03 2.400
So it's working great now. I wonder why it failed before. One possibility: powerfail (thanks PGE), and the NAS came back faster than the router?
@Jon Krueger Glad it's fixed. Put a UPS on your IT kit.
Those delay, offset, and jitter times are exactly why I serve NTP time from my FW. All clients are using the same local NTP server.
