blueI5land
- Oct 30, 2021
Hello all I'll try to keep this as short as I can but I have to TL;DR explain:
About a year ago I set up trueNas on an older machine. Everything went great had a few hiccups but I got it all running at my home. I would access the machine via another desktop that I would consider my main desktop in the house.
I have since moved the nas to an office location where I am trying to set up a small local area network.
Here is the setup at the new location:
The internet is provided via Ethernet and also wireless throughout the building. I am not yet connected to the internet but I am able to connect over LAN with wireless to the machine since the laptop does not have an ethernet port.
I am using an older Asus ac1900 router that is called a cellspot from T-Mobile I ended up getting it for free. I'm able to access the router and I see the NAS and can communicate just fine with the NAS.
I have a newer laptop that I am using to access the nas.
In an earlier thread I mentioned I forgot to connect one of my disks and was having trouble with getting everything running. However I fixed that issue but I'm having another issue that I can't seem to fix and would appreciate some assistance.
Because I already had the nas running correctly, I had sort of assumed I could just log in and view my files but I realized that because I'm using a laptop that I had not used before, the network drive was not mapped to this laptop.
When I look in my network settings. In capital letters I see TRUENAS. But when I click on it it doesn't go anywhere. So in my infinite wisdom I decided to delete the user associated with the account and also strip all ACL, and start over and so I made a new user with a new group I followed several tutorials online and YouTube videos. I'm fairly confident I set it up correctly with the new permissions however I could be wrong.
So I'm stuck at the point where I right click on network and click map network drive and then I go to a prompt for the username and password.
I'm hoping I didn't completely screw this up by deleting the original user. But the part that baffles me, is that I am 100% sure of the password I am using that I set up with the new user, but when I enter it into the windows map Network credentials it simply doesn't work.
Where do I go from here?
