tmacka88
- Jul 5, 2011
Ok, I connect to my freenas system through AFP. All of a sudden I cannot connect to the system through AFP at all, everytime it trys to connect i get this error msg
I can still connect through the GUI IP.
This seamed to happen straight after I used the GUI shell to make a directory within the jail
scripts being the folder...
any ideas?
also it seamed to make the dir ok
			There was a problem connecting to the server “FreeNAS”.
The server may not exist or it is unavailable at this time. Check the server name or IP address, check your network connection, and then try again.
jexec 1 csh
mkdir /usr/pbi/sabnzbd-amd64/data/scripts
any ideas?
[root@FreeNAS ~]# cd /mnt/tank/Jail/pluginjail/usr/pbi/sabnzbd-amd64/data
[root@FreeNAS /mnt/tank/Jail/pluginjail/usr/pbi/sabnzbd-amd64/data]# ls
Downloads
config.ini
.bak
scripts
admin
logs
config.ini
sabnzbd-8080.pid
