MrAnderson
- Oct 22, 2019
Howdy ya'll,
Now I know this question has been asked many many many times but I don't know if the answers I found relate to me or I'm not sure how to relate it to me, what i want to do is fairly simple and nothing too crazy(i hope).
I'm working on building a freeNas 11 Server ; And what I'm trying to accomplish is having a storage system that'll back up my files across multiple HDD so i have a long term backup storage system and to be able to access the files using nextcloud. I'm comfortable with the build of my system the hardware I need but i'm not sure on storage I bought 4 x 2TB because that's how much the budget allowed for, however i see for Raidz2 it's best to have 6 - 8 HDD. (I know raidz2 is not my only option)
I guess my question is can i accomplish what i need to accomplish with 4 x 2TB HDD for now and expand later : (Storage backup with redundancy)
I'll take any articles you can provide or any advice.
Should I use raidz2 if i only have 4 x 2TB : I know if i use raidz2 if one drives fails everything is okay but that drive should be replaced - if two drives fail i lose everything inside of the pool is there a better option to use ?
