JonnyAlpha
 - Jul 12, 2012
OK;
So many years ago I built a FreeNAS system using an old Pentium PC (low spec and minimum RAM). It only gets turned on now and again but it's still working
Anyway the time has now come to rebuild and finally have all of my media and data in one place accessible to all devices on my Network.
I don't have a lot of money to spend so I am looking at doing this on a low budget.
Bottom line (based on the info below) for around £200 would you guys and gals recommend a Dell Power Edge or something else. I am more than capable of building one myself.
Many thanks
Information
Some time ago I was looking at a Dell Power Edge (low end server) and have started to look again. I posted on here and I think the consensus was that 'it would be ok'. There is a used T110 II NR Xeon Quad on Amazon for £283. And lots of various Dell Power Edges T110's on eBay which seem to be a mix of the same Xeon Processor, Core i3 and others.
The T110's on eBay are around £100 - £200 varying specifications.
I have just spotted a Dell Poweredge T410 Tower Server (E5645 Hex 6 Core/16GB/No HDD/SBS 2011 COA) 15J for £119. This is about 9 years old.
As I am not particularly versed in CPU types I checked out this Wiki which lists all of the Dell Power Edges. The T110 and the T410 are both 11th Generation Power Edges with 2 types of T110 being manufactured. The T410 is older 2009, but has 2 x CPU whereas the T110 has only 1 x CPU the later model is fitted with either Intel Celeron G400 / G500, Intel Pentium G600 / G800, Xeon E3-1200, Xeon E3-1200 v2.
I only intend on fitting 3 - 4 HDD's so the T410 with 6 bays is a bit of overkill.
Many thanks
Information
