Hi everyone,
I am trying to get an Arduino connected via USB to my NodeRed iocage. I admit I'm a noob when it comes to FreeBSD, any help is greatly appreciated.
Here are the things I have done so far.
1) Created a custom devfs_ruleset and assigned that to my jail, this executes on reboot of the NAS. This has allowed me to see the port within the iocage. I did the same for a Z-Wave controller and that is working fine (although that shows up as a slightly different name and is part of the dialer group)
2) Modified permissions for the port (should be /dev/ttyU1 U0 a prior connection from this device when I swapped ports I believe)
3) Added the nodered user to the wheel group
Here is the output for my devices, this is within the iocage
Here is the output from running id nodered
Finally here is the response in NodeRED
"serial port /dev/ttyU1 error: Error: Error: Permission denied, cannot open /dev/ttyU1"
I think this is some permissions issue I am missing... like I said I'm a bit of a nub when it comes to this... thanks in advance.
#!/bin/sh
## Create custom devfs_ruleset RULE_NUM
RULE_NUM=99
/sbin/devfs rule -s ${RULE_NUM} add include 1
/sbin/devfs rule -s ${RULE_NUM} add include 2
/sbin/devfs rule -s ${RULE_NUM} add include 3
/sbin/devfs rule -s ${RULE_NUM} add path zfs unhide
/sbin/devfs rule -s ${RULE_NUM} add path 'bpf*' unhide
/sbin/devfs rule -s ${RULE_NUM} add path 'cua*' unhide
/sbin/devfs rule -s ${RULE_NUM} add path 'tty*' unhide2) Modified permissions for the port (should be /dev/ttyU1 U0 a prior connection from this device when I swapped ports I believe)
root@NodeRed:~ # ls -l /dev/tt* crw------- 1 root wheel 0xf1 May 22 15:20 /dev/ttyU0 crw------- 1 root wheel 0xf2 May 22 15:20 /dev/ttyU0.init crw------- 1 root wheel 0xf3 May 22 15:20 /dev/ttyU0.lock crw----rw- 1 root wheel 0xeb May 22 16:16 /dev/ttyU1 crw------- 1 root wheel 0xec May 22 16:16 /dev/ttyU1.init crw------- 1 root wheel 0xf9 May 22 16:16 /dev/ttyU1.lock
uid1880(nodered) gid=1880(nodered) groups=1880(nodered), 0(wheel),66(uucp)
