NodeRED FreeNAS-11.3-U2.1 USB Permissions
mvcutter
Hi everyone,
I am trying to get an Arduino connected via USB to my NodeRed iocage. I admit I'm a noob when it comes to FreeBSD, any help is greatly appreciated.
Here are the things I have done so far.
1) Created a custom devfs_ruleset and assigned that to my jail, this executes on reboot of the NAS. This has allowed me to see the port within the iocage. I did the same for a Z-Wave controller and that is working fine (although that shows up as a slightly different name and is part of the dialer group)
#!/bin/sh
## Create custom devfs_ruleset RULE_NUM
RULE_NUM=99
/sbin/devfs rule -s ${RULE_NUM} add include 1
/sbin/devfs rule -s ${RULE_NUM} add include 2
/sbin/devfs rule -s ${RULE_NUM} add include 3
/sbin/devfs rule -s ${RULE_NUM} add path zfs unhide
/sbin/devfs rule -s ${RULE_NUM} add path 'bpf*' unhide
/sbin/devfs rule -s ${RULE_NUM} add path 'cua*' unhide
/sbin/devfs rule -s ${RULE_NUM} add path 'tty*' unhide
2) Modified permissions for the port (should be /dev/ttyU1 U0 a prior connection from this device when I swapped ports I believe)
3) Added the nodered user to the wheel group
Here is the output for my devices, this is within the iocage
root@NodeRed:~ # ls -l /dev/tt*
crw-------  1 root  wheel  0xf1 May 22 15:20 /dev/ttyU0
crw-------  1 root  wheel  0xf2 May 22 15:20 /dev/ttyU0.init
crw-------  1 root  wheel  0xf3 May 22 15:20 /dev/ttyU0.lock
crw----rw-  1 root  wheel  0xeb May 22 16:16 /dev/ttyU1
crw-------  1 root  wheel  0xec May 22 16:16 /dev/ttyU1.init
crw-------  1 root  wheel  0xf9 May 22 16:16 /dev/ttyU1.lock
Here is the output from running id nodered
uid1880(nodered) gid=1880(nodered) groups=1880(nodered), 0(wheel),66(uucp)
Finally here is the response in NodeRED
"serial port /dev/ttyU1 error: Error: Error: Permission denied, cannot open /dev/ttyU1"
I think this is some permissions issue I am missing... like I said I'm a bit of a nub when it comes to this... thanks in advance.
mvcutter
I actually got it to work by running chmod a+rw /dev/ttyU*
While this works, it looks like its not ideal permission wise... Also when I disconnected/reconnected the port, it changed to ttyU2 needing new permissions... I'm sure there is a better way of granting the permissions I need in the back end to all tty* devices and I can handle the port changes on the NodeRed front end.... so I guess this is my updated question :) thanks!
Based on what you show there, you need to run as root and not nodered (I don't know if you can really chmod on devices passed through to a jail from the host via devfs).
