I don't know what happens, I Just restarted my server and now the whole app system is not working
root@beta-server[~]# k3s kubectl get pods -A NAMESPACE NAME READY STATUS RESTARTS AGE kube-system coredns-d76bd69b-wxxxn 0/1 Error 114 5d21h kube-system openebs-zfs-controller-0 0/5 Error 151 5d21h ix-shinobi-nvr shinobi-nvr-ix-chart-7c5b55b6c7-mplj4 0/1 Terminating 0 4d17h kube-system openebs-zfs-node-bfjbk 1/2 CrashLoopBackOff 26 (2m17s ago) 5d21h
root@beta-server[~]# k3s kubectl get nodes -A NAME STATUS ROLES AGE VERSION ix-truenas NotReady control-plane,master 5d21h v1.23.5+k3s-fbfa51e5-dirty
root@beta-server[~]# k3s kubectl describe nodes ix-truenas
Roles: control-plane,master
Labels: beta.kubernetes.io/arch=amd64
beta.kubernetes.io/os=linux
kubernetes.io/hostname=ix-truenas
node-role.kubernetes.io/control-plane=true
node-role.kubernetes.io/master=true
openebs.io/nodeid=ix-truenas
openebs.io/nodename=ix-truenas
Annotations: csi.volume.kubernetes.io/nodeid: {"zfs.csi.openebs.io":"ix-truenas"}
k3s.io/node-args:
["server","--cluster-cidr","172.16.0.0/16","--cluster-dns","172.17.0.10","--data-dir","/mnt/Main pool/ix-applications/k3s","--kube-apiserv...
k3s.io/node-config-hash: XYYS4OMZPCCXD42QHOZBQ7S2EHLKXRGUUQZYYV562LD2Q5LW53TQ====
k3s.io/node-env: {"K3S_DATA_DIR":"/mnt/Main pool/ix-applications/k3s/data/ff6f39c3a41a6a1bacb2d725eceedfc101fb13e2966798b12e735eae4ffe665b"}
node.alpha.kubernetes.io/ttl: 0
volumes.kubernetes.io/controller-managed-attach-detach: true
CreationTimestamp: Sun, 26 Jun 2022 15:51:10 +0500
Taints: node.kubernetes.io/not-ready:NoSchedule
Unschedulable: false
Lease:
HolderIdentity: ix-truenas
AcquireTime: <unset>
RenewTime: Sat, 02 Jul 2022 13:43:16 +0500
Conditions:
Type Status LastHeartbeatTime LastTransitionTime Reason
Message
MemoryPressure False Sat, 02 Jul 2022 13:39:13 +0500 Sat, 02 Jul 2022 12:05:05 +0500 KubeletHasSufficientMemory kubelet has sufficient memory available
DiskPressure False Sat, 02 Jul 2022 13:39:13 +0500 Sat, 02 Jul 2022 12:05:05 +0500 KubeletHasNoDiskPressure kubelet has no disk pressure
PIDPressure False Sat, 02 Jul 2022 13:39:13 +0500 Sat, 02 Jul 2022 12:05:05 +0500 KubeletHasSufficientPID kubelet has sufficient PID available
Ready False Sat, 02 Jul 2022 13:39:13 +0500 Sat, 02 Jul 2022 12:23:18 +0500 KubeletNotReady
container runtime network not ready: NetworkReady=false reason:NetworkPluginNotReady message:docker: network plugin is not ready: cni config uninitialized
Addresses:
InternalIP: 192.168.1.250
Hostname: ix-truenas
Capacity:
cpu: 4
ephemeral-storage: 4110298624Ki
hugepages-2Mi: 0
memory: 8094644Ki
pods: 250
Allocatable:
cpu: 4
ephemeral-storage: 3998498498292
hugepages-2Mi: 0
memory: 8094644Ki
pods: 250
System Info:
Machine ID: 8939c8e5d8154934ab69f390561fe785
System UUID: 30303734-3536-5a43-3133-303830313357
Boot ID: b7ab9ed1-2336-4ff6-8950-9fea5daa5e48
Kernel Version: 5.10.120+truenas
OS Image: Debian GNU/Linux 11 (bullseye)
Operating System: linux
Architecture: amd64
Container Runtime Version: docker://Unknown
Kubelet Version: v1.23.5+k3s-fbfa51e5-dirty
Kube-Proxy Version: v1.23.5+k3s-fbfa51e5-dirty
PodCIDR: 172.16.0.0/16
PodCIDRs: 172.16.0.0/16
Non-terminated Pods: (4 in total)
Namespace Name CPU Requests CPU Limits Memory Requests Memory Limits Age
kube-system coredns-d76bd69b-wxxxn 100m (2%) 0 (0%) 70Mi (0%) 170Mi (2%) 5d21h
kube-system openebs-zfs-controller-0 0 (0%) 0 (0%) 0 (0%) 0 (0%) 5d21h
ix-shinobi-nvr shinobi-nvr-ix-chart-7c5b55b6c7-mplj4 0 (0%) 0 (0%) 0 (0%) 0 (0%) 4d17h
kube-system openebs-zfs-node-bfjbk 0 (0%) 0 (0%) 0 (0%) 0 (0%) 5d21h
Allocated resources:
(Total limits may be over 100 percent, i.e., overcommitted.)
Resource Requests Limits
cpu 100m (2%) 0 (0%)
memory 70Mi (0%) 170Mi (2%)
ephemeral-storage 0 (0%) 0 (0%)
hugepages-2Mi 0 (0%) 0 (0%)
Events:
Type Reason Age From Message
Normal NodeHasSufficientMemory 98m (x16 over 5d21h) kubelet Node ix-truenas status is now: NodeHasSufficientMemory
Normal NodeHasNoDiskPressure 98m (x16 over 5d21h) kubelet Node ix-truenas status is now: NodeHasNoDiskPressure
Normal NodeHasSufficientPID 98m (x16 over 5d21h) kubelet Node ix-truenas status is now: NodeHasSufficientPID
Normal NodeReady 98m (x17 over 5d21h) kubelet Node ix-truenas status is now: NodeReady
Normal Starting 79m kubelet Starting kubelet.
Normal NodeHasSufficientMemory 79m kubelet Node ix-truenas status is now: NodeHasSufficientMemory
Normal NodeHasNoDiskPressure 79m kubelet Node ix-truenas status is now: NodeHasNoDiskPressure
Normal NodeHasSufficientPID 79m kubelet Node ix-truenas status is now: NodeHasSufficientPID
Warning Rebooted 79m kubelet Node ix-truenas has been rebooted, boot id: d3cd51dc-95a5-400e-b922-808175797f94
Normal NodeNotReady 79m kubelet Node ix-truenas status is now: NodeNotReady
Normal NodeAllocatableEnforced 79m kubelet Updated Node Allocatable limit across pods
Normal Starting 64m kubelet Starting kubelet.
Normal NodeHasSufficientMemory 64m kubelet Node ix-truenas status is now: NodeHasSufficientMemory
Normal NodeHasNoDiskPressure 64m kubelet Node ix-truenas status is now: NodeHasNoDiskPressure
Normal NodeHasSufficientPID 64m kubelet Node ix-truenas status is now: NodeHasSufficientPID
Warning Rebooted 64m kubelet Node ix-truenas has been rebooted, boot id: b7ab9ed1-2336-4ff6-8950-9fea5daa5e48
Normal NodeAllocatableEnforced 64m kubelet Updated Node Allocatable limit across pods
Normal Starting 34m kubelet Starting kubelet.
Normal NodeAllocatableEnforced 34m kubelet Updated Node Allocatable limit across pods
Normal NodeHasSufficientMemory 34m kubelet Node ix-truenas status is now: NodeHasSufficientMemory
Normal NodeHasNoDiskPressure 34m kubelet Node ix-truenas status is now: NodeHasNoDiskPressure
Normal NodeHasSufficientPID 34m kubelet Node ix-truenas status is now: NodeHasSufficientPID
