SOLVED No Web GUI after Core -> Scale upgrade
Aikidoka
I migrated from TrueNAS Core 13 to TrueNAS Scale today. The Web GUI is not accessible on any of the IPs listed. I also cannot ping or SSH to those addresses. At first I thought it was some issue with three of the IPs being on a truck to different VLANs. I plugged the cable back in I use for initial configuration to bypass any VLANs, got an IP, and still no dice. That same port, and IP, was how I initially configured my TrueNAS Core 13 install just before when I swapped over to SSDs as boot devices. What is odd is that my SMB shares are up and responsive. Looking for any info on how to check the services to ensure they are running.
Aikidoka
I used the CLI to remove all my IP configs from the VLAN. I noticed I could not ping out of those IPs, but could out of the direct connection, which was the same subnet as one of the VLANs. After that I could get into the GUI and see the issue. I have a link agg bond of my two 10Gb ports. TrueNAS Scale named the actual interfaces differently than Core, so the Bond was no good. Once I removed the old interfaces from the Bond and added the new ones, those connections came back to life I can could re-IP them.
